Home » Modeling » EMF » Formatter2 - QualifiedName formatted with spaces between delimeter
Formatter2 - QualifiedName formatted with spaces between delimeter [message #1816829] Thu, 07 November 2019 21:10 Go to next message
Brandon Lewis is currently offline Brandon LewisFriend
I don't want to say I'm at the last of my headaches with Formatter2, but I'm getting close.
I've put off getting proper formatting of my QualifiedNames for a while now, but now I can't put it off any longer.
In my formatter code, I have retrieved the region for my feature. "region" here being an NodeSemanticRegion
If I examine the region.text, I see in the debugger, my qualified name written like this:
com . lib . item . 1.0
So there are single white spaces between each QualifiedName delimiter.
I've spent at least 2 hours trying to eliminate those spaces and I can't figure it out. Hardly any of the API for region have any comment or text whatsoever.
Something like region.createWhiteSpaceReplacer seems like it would be a fit, but no docs.
This also seems like it's trivially basic to anyone who knows what they are doing - clearly not myself.
I've tried:
    val keywords = regionFor.keywords(".")
    for (keyword : keywords) {
      keyword.surround[highPriority; noSpace]
But on this region, there are no '.' keywords returned.
I can't seem to replace region.text .replace(" ", "") either. Doesn't seem theres a setText api to region.
Lost. Totally lost. Over white space surround a period.
[Updated on: Thu, 07 November 2019 21:17]
Report message to a moderator
Re: Formatter2 - QualifiedName formatted with spaces between delimeter [message #1816831 is a reply to message #1816829] Thu, 07 November 2019 22:14 Go to previous messageGo to next message
I assume you meant to post this on the TMF forum.
Re: Formatter2 - QualifiedName formatted with spaces between delimeter [message #1816858 is a reply to message #1816831] Fri, 08 November 2019 15:28 Go to previous message
You're correct. Sorry about that. I'll ask the mods to delete.
Previous Topic:EMF Compare - ADD / DELETE differences list
Next Topic:Run Eclipse Epsilon code generation online
Current Time: Wed Feb 26 20:40:05 GMT 2020
Powered by FUDForum. Page generated in 0.01876 seconds
