Re: Building forte with opc_ua [message #1816702 is a reply to message #1816666] |
Tue, 05 November 2019 10:51 |
Niklas Huhs Messages: 32 Registered: October 2019 |
Member |
Good morning,
as there were Issues again with VS, I decided to use mingw-w64 which I downloaded at the link you provided.
Now unfortunately there is a problem when trying to compile open62541. (see the screenshot)
I use the v0.3.0 branch like stated here: https://www.eclipse.org/4diac/documentation/html/communication/opc_ua.html
when configuring in CMake I use MinGWMakefiles as the generator and it automatically detects the compilers in the path of the mingw-w64 install.
configuring and generating works without problems but when trying to compile it shows this error.
p.s.: I would really like to continue working with 4diac as it fits my project perfectly and I would be very thankful if you could help me with this problem.
edit:
its working now after installing the module "six" for python
but when running forte I get the error that libopen62541.dll cannot be found. the path and name are correct in the CMake setup
[Updated on: Tue, 05 November 2019 11:40] Report message to a moderator
FUDForum. Page generated in 0.03189 seconds
