Home » Eclipse Projects » NatTable » Trouble with content assist in TextCellEditor
Trouble with content assist in TextCellEditor [message #1816602] Fri, 01 November 2019 05:46 Go to next message
Hi!
We´re trying to add content assist to some cells in a table by calling TextCellEditor.enableContentProposal(), but it does not seem to work properly.
When triggering the content proposal popup in the text cell, the cell editor looses focus in such a way that it's impossible to input more characters to filter the proposals. The expected behavior in my view is that one should be able to continue to write in the cell editor, and use the arrow and enter keys to interact with the proposal popup.
Is there some configuration that we have missed, or is this a bug? If the latter, would it be possible to work around in some way without rewriting the whole content assist support?
I've attached a small sample project that shows the problem, and also included an example from JFace which shows the expected behavior.
Maria
Re: Trouble with content assist in TextCellEditor [message #1816615 is a reply to message #1816602] Fri, 01 November 2019 10:41 Go to previous messageGo to next message
Looks like a regression between the old JFace implementation on which the support was initially implemented and the current JFace implementation.
You can override TextCellEditor#configureContentProposalAdapter to not setting the focus on the popup. That should at least fix the focus issue. But strangely the selection in the proposal jumps.
Please create a ticket so I don't forget to fix this. If you find a fix it would also be great to get a patch via Gerrit.
Re: Trouble with content assist in TextCellEditor [message #1816649 is a reply to message #1816615] Mon, 04 November 2019 03:09 Go to previous messageGo to next message
Thank you for the answer!
I noticed the same with the fix you're suggesting, for some reason the keystrokes trigger multiple calls to a listener in ContentProposalAdapter which makes the selection jump two steps. I don't know how to fix that though.
I'll create a ticket for this.
It's also worth noting that we're on NatTable 1.5 and JFace 3.11.1, so it can't be a new issue.
/Maria
[Updated on: Mon, 04 November 2019 03:19] by Moderator
Re: Trouble with content assist in TextCellEditor [message #1816656 is a reply to message #1816649] Mon, 04 November 2019 03:59 Go to previous messageGo to next message
Created https://bugs.eclipse.org/bugs/show_bug.cgi?id=552651
Re: Trouble with content assist in TextCellEditor [message #1816694 is a reply to message #1816656] Tue, 05 November 2019 03:38 Go to previous messageGo to next message
I think I was able to fix this. The two step issue is because of the InternalTraverseListener. This one should not be executed in case a proposal popup is open. You can have a look at the Gerrit patch to see how I solved this in Core.
You should be able to fix it the same way by overriding TextCellEditor#enableContentProposal() the same way.
Re: Trouble with content assist in TextCellEditor [message #1816697 is a reply to message #1816694] Tue, 05 November 2019 04:44 Go to previous message
Works great, thank you very much for your time!
/Maria
Previous Topic:Comboboxcelleditor combo values based on cell value
Next Topic:Generating PDF in NatTable
Current Time: Mon Jun 16 09:54:57 EDT 2025
Powered by FUDForum. Page generated in 0.39581 seconds
