Home » Newcomers » Newcomers » Hover when code isn't selected(How to create a hover that activates when the code is not selected?)
Hover when code isn't selected [message #1816137] Tue, 22 October 2019 05:32 Go to next message
Andrew Myers is currently offline Andrew MyersFriend
In the Java Editor if I put my cursor over a class name I get a hover (if that's the right word?) like the one in the attached screen clipping.
The developer docs have an example for hover such as this:
https://help.eclipse.org/kepler/topic/org.eclipse.platform.doc.isv/guide/editors_hover.htm
But it requires the text to be selected first, rather than simply placing your mouse over the word.
In a plugin I'm writing, what do I need to do in order to replicate that behaviour (ie. the triggering of the hover by placing the mouse in a certain position - I understand I'll need to work what will be displayed when the cursor is in a particular position..).
Andrew.
Re: Hover when code isn't selected [message #1816171 is a reply to message #1816137] Wed, 23 October 2019 07:52 Go to previous messageGo to next message
Probably it's good to look in the source code of some other thing that already does what you want. This tutorial describes how to get all the sources for the whole platform SDK in your workspace.
https://wiki.eclipse.org/Eclipse_Platform_SDK_Provisioning
Likely you'll only really need the JDT parts to see how the Java editor implements this.
Ed Merks
Re: Hover when code isn't selected [message #1816221 is a reply to message #1816171] Thu, 24 October 2019 09:37 Go to previous message
Thanks Ed
Previous Topic:No Colors in code window
Next Topic:Eclipse Mars.2 Display Issue
Current Time: Fri Mar 05 09:56:23 GMT 2021
Powered by FUDForum. Page generated in 0.02684 seconds
