Home » Eclipse Projects » Rich Client Platform (RCP) » Error on exporting product
Error on exporting product [message #1815977] Wed, 16 October 2019 12:55 Go to next message
Banafsheh Azizi is currently offline Banafsheh AziziFriend
Hi there,
I have got the bellow error after exporting the product as `Eclipse product`. What shall I do? I have searched about this error but I couldn't find the solution. I am using Eclipse SDK, 2019-09 (4.13).
C:\Users\apple\workspace1\.metadata\.plugins\org.eclipse.pde.core\temp\org.eclipse.pde.container.feature\package.org.eclipse.pde.container.feature.win32.win32.x86_64.xml:90: The following error occurred while executing this line:
C:\Users\apple\workspace1\.metadata\.plugins\org.eclipse.pde.core\temp\org.eclipse.pde.container.feature\package.org.eclipse.pde.container.feature.win32.win32.x86_64.xml:501: The following error occurred while executing this line:
W:\RCP\eclipse\plugins\org.eclipse.pde.build_3.10.500.v20190620-0530\scripts\genericTargets.xml:240: A problem occured while invoking the director.
Looking forward to your prompt reply,
Best Regards,
Banafsheh
Member of MDSE Research Group
http://mdse.ui.ac.ir
[Updated on: Wed, 16 October 2019 13:00]
Report message to a moderator
Re: Error on exporting product [message #1815983 is a reply to message #1815977] Wed, 16 October 2019 13:26 Go to previous messageGo to next message
Brian de Alwis is currently offline Brian de AlwisFriend
Use Tycho to do your builds instead. The _Export_ for a product is difficult to diagnose and should probably be removed.
https://www.eclipse.org/tycho/documentation.php
Re: Error on exporting product [message #1815994 is a reply to message #1815983] Wed, 16 October 2019 16:24 Go to previous messageGo to next message
Thanks for your reply. I think it is due to the fact I have fixed the error of missing plugin in the run configuration. The truth is when I launch an eclipse application, it has a error said "missing test.rcp". "test.rcp" is its own name. What shall I do for that?
Re: Error on exporting product [message #1816134 is a reply to message #1815994] Tue, 22 October 2019 05:00 Go to previous message
It was solved. I have added all dependencies in the content tab of the rcp plugin and also in the included plugins of its feature. So, it was launched correctly without needing to add required plugins in the run configuration. In the export wizard, I have unchecked the `Generate p2 repository`.
[Updated on: Tue, 22 October 2019 05:10]
Previous Topic:Tooltip not getting set for Command having new Wizard
Next Topic:Plugin execution after "Install into host. Repository:" destination
Current Time: Sat May 15 21:53:12 GMT 2021
Powered by FUDForum. Page generated in 0.01603 seconds
