Home » Eclipse Projects » SWTBot » How to press shortcuts containing numpad keys?
How to press shortcuts containing numpad keys? [message #1815683] Tue, 08 October 2019 11:26 Go to next message
Matthias Bank is currently offline Matthias BankFriend
I want to test the shortcut Ctrl+Numpad_Subtract in my editor. I tried
SWTBotEditor editor = bot.editorByTitle("my.editor");
SWTBotTree tree = editor.bot().tree(0);
tree.pressShortcut(Keystrokes.CTRL, KeyStroke.getInstance("NUMPAD_SUBTRACT"));
This doesn't work. Other shortcuts without numpad keys work fine with the code above, e.g. Ctrl+M. Is this a bug or is there any trick to test shortcuts containing numpad keys?
Re: How to press shortcuts containing numpad keys? [message #1815708 is a reply to message #1815683] Tue, 08 October 2019 15:04 Go to previous messageGo to next message
Patrick Tasse is currently offline Patrick TasseFriend
Member
Hi Matthias,
What you're doing seems correct, also equivalent to:
tree.pressShortcut(Keystrokes.CTRL, KeyStroke.getInstance(0, SWT.KEYPAD_SUBTRACT));
However, it does not work because AWTKeyboardStrategy in SWTBot is missing the natural key mapping for this key. (I assume you are using AWT keyboard)
It could be added (and, at the same time, Keystrokes.KEYPAD_SUBTRACT so you can use it directly). We should add all the other keypad keystrokes too...
Can you submit a patch, or else write a bug report?
Patrick
Re: How to press shortcuts containing numpad keys? [message #1815728 is a reply to message #1815708] Wed, 09 October 2019 09:16 Go to previous message
Thanks for your hint, adding the missing mappings was straightforward. I am using SWT keyboard, which has the same bug.
I currently can't commit the fix because of our company policy. This policy will change hopefully before Christmas, then I will commit the fix.
Previous Topic:SWTBot with Cucumber
Next Topic:Open SWTBot test Recorder with RCP application
Current Time: Fri Oct 07 22:53:42 GMT 2022
Powered by FUDForum. Page generated in 0.02454 seconds
