Home » Modeling » M2T (model-to-text transformation) » [Acceleo] A question on building product with Maven/Tycho
[Acceleo] A question on building product with Maven/Tycho [message #1815593] Sun, 06 October 2019 15:14 Go to next message
Akira Tanaka is currently offline Akira TanakaFriend
Member
Dear Acceleo experts,
I have created a Sirius-based DSL editor and associated model transformation with Acceleo and Acceleo UI. I looked for documentation for building a product and found the following section.
https://wiki.eclipse.org/Acceleo/User_Guide#Building_an_Acceleo_generator_with_Maven_and_Tycho
It talks about adding an optional dependency to MANIFEST.MF and generate POMs. The generated POM contains the following part.
 <repositories>
    <repository>
      <id>Indigo Release</id>
      <url>https://raw.github.com/eclipse/acceleo/master/maven/repository/releases/indigo</url>
    </repository>
	<repository>
      <id>Juno Release</id>
      <url>https://raw.github.com/eclipse/acceleo/master/maven/repository/releases/juno</url>
    </repository>
	<repository>
      <id>Snapshots</id>
      <url>https://raw.github.com/eclipse/acceleo/master/maven/repository/snapshots</url>
    </repository>
 </repositories>
Indigo and Juno are old releases. Is the above still valid? I hope the section would be updated soon. And, if there are any recent examples or explanations, please let us know.
Akira
Re: [Acceleo] A question on building product with Maven/Tycho [message #1815598 is a reply to message #1815593] Sun, 06 October 2019 20:24 Go to previous messageGo to next message
I strongly recommend that you reconsider what you build manually and what you build automatically.
IIRC from when I was trying to build Acceleo using Buckminster, it is really hard because you are trying to empathize with something that just does magic things remotely. I gave up and treated the Acceleo outputs just like primary source artefacts in GIT for downstream builds.
Maven and Tycho can execute locally so debugging is a bit easier, but the file paths change to include a "target/...." duplicate which is likely to make Acceleo's broken URI resolution even more temperamental.
I really wouldn't waste your time trying to do the near impossible and arguably also the irresponsible. IMHO many auto-generated artefacts should only change for a release, not every build and when they change the change may need API compatibility tweaks. Just not possible with an auto break-the-API Maven re-build.
Ed Willink
Re: [Acceleo] A question on building product with Maven/Tycho [message #1815606 is a reply to message #1815598] Mon, 07 October 2019 05:30 Go to previous messageGo to next message
Member
Thank you very much for your recommendation. I will then consider a simpler solution.
Best,
Akira
Re: [Acceleo] A question on building product with Maven/Tycho [message #1815650 is a reply to message #1815606] Mon, 07 October 2019 20:12 Go to previous message
To be clear, when I recommend manual building, I do not mean interactive commands. Rather a script, I prefer MWE2, but you might prefer ANT, can be launched to perform the requisite auto-generation predictably and on demand.
Ed Willink
Previous Topic:Parsing OCL constraints in Acceleo
Next Topic:Code Generation via NLP
Current Time: Sat Jul 24 16:09:43 GMT 2021
Powered by FUDForum. Page generated in 0.01832 seconds
