Re: Is there any command to change font size in the platform? [message #336340 is a reply to message #336337] |
Tue, 09 June 2009 07:48 |
Originally posted by: aurelien.pupier.esial.net
Hiroki Kondo a écrit :
> Hello,folks!
> In Eclipse 3.5,
> There is a font size change feature on the welcome view.
> Is there similar feature in Eclipse?
> In Japan, people want to use Eclipse during presentation,
> They want to change font to adjust on the projector at the presentation.
> Yes, I know the plug-in Font Size Changer for this purpose.
> http://flymewiththeeclipseway.blogspot.com/2009/03/font-size -changer-it-is-good-plug-in.html
> I would like to do this in default Eclipse.
> Could someone suggest an idea for this use case?
Look in Window->Preferences->General->Appearance->Colors and Font
select the target ou want to change :
like Basic->text Font thne click Change and choose your font ;)
Like that you need to change various and multiple fonts by hand (not so
much finally) I don't kniow if we can change all in one time.
hope this will help
Aurélien Pupier
Re: Is there any command to change font size in the platform? [message #336391 is a reply to message #336379] |
Wed, 10 June 2009 07:27 |
> Thank you for reply and tell me how to change font size at
> Preferences,Aurélien.
> I'm looking for how to change font's size using short-cut.
> Do you know some OS supports zoom-in and zoom-out using short-cut?
> I want to do this on Eclipse in the presentation.
> Because sometimes I explain some code in the presentation with my friends.
> Someone will say "Excuse me,Could you change font size to be more
> bigger?I can't read these code."
> "OK. I'll change it...".
> I want to change the size using short-cut,because it is smart!
> How do you think this? Is it new Eclipse's enhancement?
You can set custom key shortcut :
Window->Preferences->General->Keys
now you have to found the corresponding command :s
>> Hi,
>> so much
> finally) I don't know if we can change all in one time.
>> hope this will help
>> Aurélien Pupier
FUDForum. Page generated in 0.03347 seconds
