Home » Eclipse Projects » Jubula » JAVA Swing UI automate the application testing(How to test java swing client UI lunch through server)
JAVA Swing UI automate the application testing [message #1815376] Tue, 01 October 2019 20:04 Go to next message
Vijay Kumar is currently offline Vijay KumarFriend
index.php/fa/36451/0/How can i automate java applets based ui using JUBULA. My problem is my applets lunched when user click from browser, applets got lunched individually. Please find the attached image, please help me on this.
Thanks in Advance.
  • Attachment: scr3.png
    (Size: 126.46KB, Downloaded 434 times)
Re: JAVA Swing UI automate the application testing [message #1815665 is a reply to message #1815376] Tue, 08 October 2019 05:37 Go to previous message
Marvin Mueller is currently offline Marvin MuellerFriend
Jubula can start and test Java web start applications once the application has been downloaded and saved to the file system. However, the actual Java web start mechanism is currently not supported.
That means jubula must start the downloaded web start application, that might be possible or not(depending on how the application is started and gets their parameters).
best regards
Marvin Mueller
Previous Topic:Cannot connet to AUT through rcp plugin
Next Topic:Autagent does not clean temp files
Current Time: Sat Feb 27 10:36:12 GMT 2021
Powered by FUDForum. Page generated in 0.02342 seconds
