Home » Language IDEs » Eclipse Web Tools Platform Project (WTP) » Where can I get JSDT-core source code?
Where can I get JSDT-core source code? [message #1814956] Mon, 23 September 2019 12:53 Go to next message
Federer Roger  is currently offline Federer Roger Friend
Member
IDE is Eclipse 2019-09. I have already installed JavaScript Developer Tool, and I only get jar project when I import as Source Project. How can I get corresponding source code of JSDT-core?
  • Attachment: jsdt.png
    (Size: 51.70KB, Downloaded 42 times)
  • Attachment: jsdt2.png
    (Size: 11.47KB, Downloaded 39 times)
[Updated on: Mon, 23 September 2019 12:54]
Report message to a moderator
Re: Where can I get JSDT-core source code? [message #1814959 is a reply to message #1814956] Mon, 23 September 2019 13:12 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin DahyabhaiFriend
You would either import from repository instead, or first install the "JavaScript Development Tools SDK" and then import the Source Project.
Nitin Dahyabhai
Re: Where can I get JSDT-core source code? [message #1814962 is a reply to message #1814959] Mon, 23 September 2019 13:34 Go to previous messageGo to next message
Member
I think I have already installed JSDT sdk like this. It doesn't work. I can't understand your first solution. Where to get the repository´╝č
  • Attachment: jsdt3.png
    (Size: 40.93KB, Downloaded 42 times)
Re: Where can I get JSDT-core source code? [message #1815047 is a reply to message #1814962] Tue, 24 September 2019 17:49 Go to previous messageGo to next message
You'll need to install eGit ("Git integration for Eclipse") first, then it will be able to find the repository automatically when you choose that option--the needed Git repository location is embedded in the plug-in itself, but the option will fail unless eGit is installed. Separately, the clone URLs would be shown using https://git.eclipse.org/r/#/admin/projects/jsdt/webtools.jsdt , as it is enabled for Gerrit.
Nitin Dahyabhai
[Updated on: Tue, 24 September 2019 17:52]
Re: Where can I get JSDT-core source code? [message #1823110 is a reply to message #1815047] Thu, 19 March 2020 14:51 Go to previous message
alexx grin is currently offline alexx grinFriend
tnx for your help! It worked for me
Previous Topic:XML Validation - how to exclude certain files?
Next Topic:Project explorer J2EE content extensions duplicity - jst.j2ee vs jst.jee
Current Time: Mon Oct 26 08:37:22 GMT 2020
Powered by FUDForum. Page generated in 0.01889 seconds
