Home » Eclipse Projects » EclipseLink » eclipselink 2.7.4 and java 13 causes java.lang.IllegalArgumentException(eclipselink under java 13 causes: java.lang.IllegalArgumentException: Unsupported class file major version 57)
eclipselink 2.7.4 and java 13 causes java.lang.IllegalArgumentException [message #1814793] Wed, 18 September 2019 11:54 Go to next message
erich siffert is currently offline erich siffertFriend
when starting an application in Tomcat 9.0.24 with Java 13 (both on Linux 3.10.0-957.27.2.el7.x86_64 and Windows 10) eclipselink throws following errors (see below). The app starts anyway and seems to work correctly (as far as I've seen...)
Is there a workaround or a new version to be expected?
regards
Erich
13:40:01,866 ERROR                          ECLIPSELINK [(|)] The java.lang.Object class was compiled with an unsupported JDK. Report this error to the EclipseLink open source project.
	at org.eclipse.persistence.internal.libraries.asm.ClassReader.<init>(ClassReader.java:184)
	at org.eclipse.persistence.internal.libraries.asm.ClassReader.<init>(ClassReader.java:166)
	at org.eclipse.persistence.internal.libraries.asm.ClassReader.<init>(ClassReader.java:152)
	at org.eclipse.persistence.internal.libraries.asm.ClassReader.<init>(ClassReader.java:273)
	at org.eclipse.persistence.internal.jpa.metadata.accessors.objects.MetadataAsmFactory.buildClassMetadata(MetadataAsmFactory.java:106)
	at org.eclipse.persistence.internal.jpa.metadata.accessors.objects.MetadataAsmFactory.getMetadataClass(MetadataAsmFactory.java:177)
	at org.eclipse.persistence.internal.jpa.metadata.accessors.objects.MetadataAccessibleObject.getMetadataClass(MetadataAccessibleObject.java:73)
	at org.eclipse.persistence.internal.jpa.metadata.accessors.objects.MetadataClass.getSuperclass(MetadataClass.java:405)
	at org.eclipse.persistence.internal.jpa.metadata.accessors.classes.ClassAccessor.processParentClass(ClassAccessor.java:1695)
	at org.eclipse.persistence.internal.jpa.metadata.MetadataProject.addAccessor(MetadataProject.java:421)
	at org.eclipse.persistence.internal.jpa.metadata.MetadataProject.addEmbeddableAccessor(MetadataProject.java:505)
	at org.eclipse.persistence.internal.jpa.metadata.MetadataProcessor.initPersistenceUnitClasses(MetadataProcessor.java:374)
	at org.eclipse.persistence.internal.jpa.metadata.MetadataProcessor.processEntityMappings(MetadataProcessor.java:563)
	at org.eclipse.persistence.internal.jpa.deployment.PersistenceUnitProcessor.processORMetadata(PersistenceUnitProcessor.java:625)
	at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.predeploy(EntityManagerSetupImpl.java:2003)
	at org.eclipse.persistence.jpa.PersistenceProvider.createContainerEntityManagerFactoryImpl(PersistenceProvider.java:350)
	at org.eclipse.persistence.jpa.PersistenceProvider.createContainerEntityManagerFactory(PersistenceProvider.java:316)
	at org.springframework.orm.jpa.LocalContainerEntityManagerFactoryBean.createNativeEntityManagerFactory(LocalContainerEntityManagerFactoryBean.java:365)
	at org.springframework.orm.jpa.AbstractEntityManagerFactoryBean.buildNativeEntityManagerFactory(AbstractEntityManagerFactoryBean.java:390)
	at org.springframework.orm.jpa.AbstractEntityManagerFactoryBean.afterPropertiesSet(AbstractEntityManagerFactoryBean.java:377)
	at org.springframework.orm.jpa.LocalContainerEntityManagerFactoryBean.afterPropertiesSet(LocalContainerEntityManagerFactoryBean.java:341)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1837)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1774)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:593)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:515)
	at org.springframework.beans.factory.support.AbstractBeanFactory.lambda$doGetBean$0(AbstractBeanFactory.java:320)
	at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:222)
	at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:318)
	at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:199)
	at org.springframework.context.support.AbstractApplicationContext.getBean(AbstractApplicationContext.java:1105)
	at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:867)
	at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:549)
	at org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:400)
	at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:291)
	at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:103)
	at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4683)
	at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5146)
	at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:183)
	at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:717)
	at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:690)
	at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:705)
	at org.apache.catalina.startup.HostConfig.deployDescriptor(HostConfig.java:631)
	at org.apache.catalina.startup.HostConfig$DeployDescriptor.run(HostConfig.java:1831)
	at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515)
	at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
	at org.apache.tomcat.util.threads.InlineExecutorService.execute(InlineExecutorService.java:75)
	at java.base/java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:118)
	at org.apache.catalina.startup.HostConfig.deployDescriptors(HostConfig.java:526)
	at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:425)
	at org.apache.catalina.startup.HostConfig.start(HostConfig.java:1576)
	at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:309)
	at org.apache.catalina.util.LifecycleBase.fireLifecycleEvent(LifecycleBase.java:123)
	at org.apache.catalina.util.LifecycleBase.setStateInternal(LifecycleBase.java:423)
	at org.apache.catalina.util.LifecycleBase.setState(LifecycleBase.java:366)
	at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:936)
	at org.apache.catalina.core.StandardHost.startInternal(StandardHost.java:841)
	at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1384)
	at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1374)
	at java.base/java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:140)
	at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:909)
	at org.apache.catalina.core.StandardEngine.startInternal(StandardEngine.java:262)
	at org.apache.catalina.core.StandardService.startInternal(StandardService.java:421)
	at org.apache.catalina.core.StandardServer.startInternal(StandardServer.java:932)
	at org.apache.catalina.startup.Catalina.start(Catalina.java:633)
	at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
	at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
	at java.base/java.lang.reflect.Method.invoke(Method.java:567)
	at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:344)
	at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:475)
13:40:01,873 ERROR                          ECLIPSELINK [(|)] The java.lang.Object class was compiled with an unsupported JDK. Report this error to the EclipseLink open source project.
java.lang.ArrayIndexOutOfBoundsException: Index 8 out of bounds for length 0
	at org.eclipse.persistence.internal.libraries.asm.ClassReader.readUnsignedShort(ClassReader.java:3353)
	at org.eclipse.persistence.internal.libraries.asm.ClassReader.<init>(ClassReader.java:188)
	at org.eclipse.persistence.internal.libraries.asm.EclipseLinkClassReader.<init>(EclipseLinkClassReader.java:32)
	at org.eclipse.persistence.internal.libraries.asm.EclipseLinkClassReader.<init>(EclipseLinkClassReader.java:28)
	at org.eclipse.persistence.internal.libraries.asm.EclipseLinkClassReader.<init>(EclipseLinkClassReader.java:24)
	at org.eclipse.persistence.internal.jpa.metadata.accessors.objects.MetadataAsmFactory.buildClassMetadata(MetadataAsmFactory.java:123)
13:40:02,073 ERROR                          ECLIPSELINK [(|)] The java.lang.Enum class was compiled with an unsupported JDK. Report this error to the EclipseLink open source project.
13:40:02,079 ERROR                          ECLIPSELINK [(|)] The java.lang.Enum class was compiled with an unsupported JDK. Report this error to the EclipseLink open source project.
Re: eclipselink 2.7.4 and java 13 causes java.lang.IllegalArgumentException [message #1815275 is a reply to message #1814793] Sun, 29 September 2019 06:09 Go to previous messageGo to next message
Sayat Sayat is currently offline Sayat SayatFriend
Stumbled across the same problem. Any solution found?
Re: eclipselink 2.7.4 and java 13 causes java.lang.IllegalArgumentException [message #1815426 is a reply to message #1815275] Wed, 02 October 2019 15:18 Go to previous message
I opened later on a bug ticket as well (https://bugs.eclipse.org/bugs/show_bug.cgi?id=551398) - it seems it will be fixed with version 2.7.5: https://github.com/eclipse-ee4j/eclipselink/pull/555
Previous Topic: null exception when using find
Next Topic:"Bug" with JPA InheritanceType SINGLE_TABLE and key
Current Time: Thu Jun 04 21:48:21 GMT 2020
Powered by FUDForum. Page generated in 0.02085 seconds
