egit plugin install fails [message #1814679] |
Mon, 16 September 2019 09:51  |
Below is the error i am getting while trying to install egit.
Cannot complete the install because one or more required items could not be found.
Software being installed: Git integration for Eclipse 5.4.2.201908231537-r (org.eclipse.egit.feature.group 5.4.2.201908231537-r)
Missing requirement: Git integration for Eclipse 5.4.2.201908231537-r (org.eclipse.egit.feature.group 5.4.2.201908231537-r) requires 'org.eclipse.core.runtime [3.12.0,4.0.0)' but it could not be found
Thanks in advance.
Re: egit plugin install fails [message #1814690 is a reply to message #1814686] |
Mon, 16 September 2019 13:17   |
You might also want to verify whether it's a feature you can already enable from within the Installation Manager. The documentation for the current release, 9.7, mentions eGit specifically as being included.
Re: egit plugin install fails [message #1815026 is a reply to message #1814690] |
Tue, 24 September 2019 11:19   |
Nitin Dahyabhai wrote on Mon, 16 September 2019 13:17You might also want to verify whether it's a feature you can already enable from within the Installation Manager. The documentation for the current release, 9.7, mentions eGit specifically as being included.
Interesting; hadn't seen that. RSA 9.7 is based on Eclipse Oxygen, so I wonder what version of EGit they'd serve. Probably 4.8 or 4.9. Those were current back then: Oxygen is already two years old.
In any case newest EGit from the normal EGit update site (either 5.5.0 or nightly) installs and works fine on RSA 9.7. No need for IBM's Installation Manager at all.
RSA 9.5 was based on a much older Eclipse version (4.4, i.e., Eclipse Luna), so recent EGit versions won't install. The latest that might work on RSA 9.5 would be EGit 5.0.3 from September 2018, which can be installed from the old 5.0.3 update site.
Re: egit plugin install fails [message #1815038 is a reply to message #1815026] |
Tue, 24 September 2019 16:04   |
Looking at the metadata
https://download.eclipse.org/oomph/archive/simrel/egit.aggrcon/http___download.eclipse.org_egit_updates-5.5/org.eclipse.egit.feature.group_5.5.0.201909110433-r.html
I.e., <required namespace="org.eclipse.equinox.p2.iu" name="org.eclipse.core.runtime" range="[3.12.0,4.0.0)"/>
<required namespace="org.eclipse.equinox.p2.iu" name="org.eclipse.core.resources" range="[3.11.0,4.0.0)"/>
<required namespace="org.eclipse.equinox.p2.iu" name="org.eclipse.core.filesystem" range="[1.6.0,2.0.0)"/>
<required namespace="org.eclipse.equinox.p2.iu" name="org.eclipse.ui" range="[3.108.0,4.0.0)"/>
<required namespace="org.eclipse.equinox.p2.iu" name="org.eclipse.team.ui" range="[3.8.0,4.0.0)"/>
<required namespace="org.eclipse.equinox.p2.iu" name="org.eclipse.jface.text" range="[3.11.0,4.0.0)"/>
<required namespace="org.eclipse.equinox.p2.iu" name="org.eclipse.ui.ide" range="[3.12.0,4.0.0)"/>
<required namespace="org.eclipse.equinox.p2.iu" name="org.eclipse.ui.workbench.texteditor" range="[3.10.0,4.0.0)"/>
<required namespace="org.eclipse.equinox.p2.iu" name="org.eclipse.compare" range="[3.6.0,4.0.0)"/>
It seems to me that indeed the latest version EGit should install in anything older than Neon...
Re: egit plugin install fails [message #1815115 is a reply to message #1815038] |
Wed, 25 September 2019 15:23   |
Ed Merks wrote on Tue, 24 September 2019 16:04It seems to me that indeed the latest version EGit should install in anything older than Neon...
Typo? Did you mean "should not"? Or "newer"? I thought we had updated all minimum requirements to what was in Neon.0 a while ago.
Re: egit plugin install fails [message #1815116 is a reply to message #1815115] |
Wed, 25 September 2019 15:30   |
IBM's own page on RSA 9.7 says they include EGit 4.1.1. Which is, even given the notoriously conservative policies IBM seems to have for updating for RSA, outright ridiculous. That's four year old version.
Re: egit plugin install fails [message #1823589 is a reply to message #1815026] |
Sun, 29 March 2020 21:33   |
i am using CIsco call studio v12.5 and having the same problem.
Missing requirement: Git integration for Eclipse 5.7.0.202003110725-r (org.eclipse.egit.feature.group 5.7.0.202003110725-r) requires 'org.eclipse.core.runtime [3.12.0,4.0.0)' but it could not be found
Cannot satisfy dependency:
From: Git integration for Eclipse - Source Code 5.7.0.202003110725-r (org.eclipse.egit.source.feature.group 5.7.0.202003110725-r)
To: org.eclipse.egit.feature.group [5.7.0,5.8.0)
Can someone please help me out?
FUDForum. Page generated in 0.08746 seconds
