Home » Newcomers » Newcomers » egit plugin install fails (Not able to install egit plugin due to dependency missing )
egit plugin install fails [message #1814679] Mon, 16 September 2019 09:51 Go to next message
Karthick Sekar is currently offline Karthick SekarFriend
Below is the error i am getting while trying to install egit.
Cannot complete the install because one or more required items could not be found.
Software being installed: Git integration for Eclipse 5.4.2.201908231537-r (org.eclipse.egit.feature.group 5.4.2.201908231537-r)
Missing requirement: Git integration for Eclipse 5.4.2.201908231537-r (org.eclipse.egit.feature.group 5.4.2.201908231537-r) requires 'org.eclipse.core.runtime [3.12.0,4.0.0)' but it could not be found
Thanks in advance.
Re: egit plugin install fails [message #1814682 is a reply to message #1814679] Mon, 16 September 2019 10:28 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin DahyabhaiFriend
Your version of Eclipse is too old. Update to the current release.
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: egit plugin install fails [message #1814683 is a reply to message #1814682] Mon, 16 September 2019 10:41 Go to previous messageGo to next message
I use Rational Application Developer and my version is up to date.
Version: 9.5
Build ID: RADO95-I20150908_2025
[Updated on: Mon, 16 September 2019 10:42]
Report message to a moderator
Re: egit plugin install fails [message #1814686 is a reply to message #1814683] Mon, 16 September 2019 11:36 Go to previous messageGo to next message
Your RAD version may well be up-to-date (though 2015 is not exactly all that recent). But that's too old to install the latest version of EGit. There are lots of old versions available:
https://download.eclipse.org/egit/
You'd need to find out which version will install, e.g., is quite old
https://download.eclipse.org/egit/updates-4.0/
Re: egit plugin install fails [message #1814690 is a reply to message #1814686] Mon, 16 September 2019 13:17 Go to previous messageGo to next message
You might also want to verify whether it's a feature you can already enable from within the Installation Manager. The documentation for the current release, 9.7, mentions eGit specifically as being included.
Nitin Dahyabhai
Re: egit plugin install fails [message #1815026 is a reply to message #1814690] Tue, 24 September 2019 11:19 Go to previous messageGo to next message
Thomas Wolf is currently offline Thomas WolfFriend
Nitin Dahyabhai wrote on Mon, 16 September 2019 13:17
Interesting; hadn't seen that. RSA 9.7 is based on Eclipse Oxygen, so I wonder what version of EGit they'd serve. Probably 4.8 or 4.9. Those were current back then: Oxygen is already two years old.
In any case newest EGit from the normal EGit update site (either 5.5.0 or nightly) installs and works fine on RSA 9.7. No need for IBM's Installation Manager at all.
RSA 9.5 was based on a much older Eclipse version (4.4, i.e., Eclipse Luna), so recent EGit versions won't install. The latest that might work on RSA 9.5 would be EGit 5.0.3 from September 2018, which can be installed from the old 5.0.3 update site.
Re: egit plugin install fails [message #1815038 is a reply to message #1815026] Tue, 24 September 2019 16:04 Go to previous messageGo to next message
Looking at the metadata
https://download.eclipse.org/oomph/archive/simrel/egit.aggrcon/http___download.eclipse.org_egit_updates-5.5/org.eclipse.egit.feature.group_5.5.0.201909110433-r.html
I.e.,
    <required namespace="org.eclipse.equinox.p2.iu" name="org.eclipse.core.runtime" range="[3.12.0,4.0.0)"/>
    <required namespace="org.eclipse.equinox.p2.iu" name="org.eclipse.core.resources" range="[3.11.0,4.0.0)"/>
    <required namespace="org.eclipse.equinox.p2.iu" name="org.eclipse.core.filesystem" range="[1.6.0,2.0.0)"/>
    <required namespace="org.eclipse.equinox.p2.iu" name="org.eclipse.ui" range="[3.108.0,4.0.0)"/>
    <required namespace="org.eclipse.equinox.p2.iu" name="org.eclipse.team.ui" range="[3.8.0,4.0.0)"/>
    <required namespace="org.eclipse.equinox.p2.iu" name="org.eclipse.jface.text" range="[3.11.0,4.0.0)"/>
    <required namespace="org.eclipse.equinox.p2.iu" name="org.eclipse.ui.ide" range="[3.12.0,4.0.0)"/>
    <required namespace="org.eclipse.equinox.p2.iu" name="org.eclipse.ui.workbench.texteditor" range="[3.10.0,4.0.0)"/>
    <required namespace="org.eclipse.equinox.p2.iu" name="org.eclipse.compare" range="[3.6.0,4.0.0)"/>
It seems to me that indeed the latest version EGit should install in anything older than Neon...
Re: egit plugin install fails [message #1815115 is a reply to message #1815038] Wed, 25 September 2019 15:23 Go to previous messageGo to next message
Ed Merks wrote on Tue, 24 September 2019 16:04
Typo? Did you mean "should not"? Or "newer"? I thought we had updated all minimum requirements to what was in Neon.0 a while ago.
Re: egit plugin install fails [message #1815116 is a reply to message #1815115] Wed, 25 September 2019 15:30 Go to previous messageGo to next message
IBM's own page on RSA 9.7 says they include EGit 4.1.1. Which is, even given the notoriously conservative policies IBM seems to have for updating for RSA, outright ridiculous. That's four year old version.
Re: egit plugin install fails [message #1815120 is a reply to message #1815116] Wed, 25 September 2019 16:23 Go to previous messageGo to next message
Yes, sorry, the "not" versus newer/older got screwed up.
Re: egit plugin install fails [message #1823589 is a reply to message #1815026] Sun, 29 March 2020 21:33 Go to previous messageGo to next message
vinod tati is currently offline vinod tatiFriend
i am using CIsco call studio v12.5 and having the same problem.
Missing requirement: Git integration for Eclipse 5.7.0.202003110725-r (org.eclipse.egit.feature.group 5.7.0.202003110725-r) requires 'org.eclipse.core.runtime [3.12.0,4.0.0)' but it could not be found
Cannot satisfy dependency:
From: Git integration for Eclipse - Source Code 5.7.0.202003110725-r (org.eclipse.egit.source.feature.group 5.7.0.202003110725-r)
To: org.eclipse.egit.feature.group [5.7.0,5.8.0)
Can someone please help me out?
Re: egit plugin install fails [message #1823599 is a reply to message #1823589] Mon, 30 March 2020 06:11 Go to previous message
So you're trying to install a new EGit into an installation with an old version of Eclipse that's not compatible with the new EGit. The only workaround for that is to find an older version of EGit that is compatible. All the EGit repos are here:
Some older version from that will work.
Previous Topic:Getting SSL cert error trying to install plugins from two different sites
Next Topic:Xtext grammar to java Code
Current Time: Thu Jul 09 18:20:21 GMT 2020
Powered by FUDForum. Page generated in 0.02756 seconds
