Home » Eclipse Projects » EGit / JGit » EGit is back to freezing behavior again
EGit is back to freezing behavior again [message #1814284] Sun, 08 September 2019 15:13 Go to next message
Benno Luthiger is currently offline Benno LuthigerFriend
I observed the same cumbersome behavior as described in "EGit freezes Eclipse in 2019-06 release" few weeks ago.
I found this problem solved after installing the EGit/Jgit releases during the last weeks.
With the newest update (5.5.0.201909051128) however, this cumbersome behavior seems to be back again.
I'm using Eclipse 2019-06 on Windows 10 with jdk1.8.0_181.
Best,
Benno
Re: EGit is back to freezing behavior again [message #1814285 is a reply to message #1814284] Sun, 08 September 2019 15:42 Go to previous messageGo to next message
Matthias Sohn is currently offline Matthias SohnFriend
Can you create a thread dump to find out what's going on ?
Re: EGit is back to freezing behavior again [message #1815129 is a reply to message #1814284] Wed, 25 September 2019 18:29 Go to previous messageGo to next message
Franz J. Hauck is currently offline Franz J. HauckFriend
It seems that I've the same problems. Just startet with fresh downloads.
Re: EGit is back to freezing behavior again [message #1815131 is a reply to message #1814285] Wed, 25 September 2019 18:58 Go to previous message
I actually had the same problems in the last years multiple times with new versions of EGit, which was very annoying.
I use Putty with Pageant and Plink. GIT_SSH set to PLINK.exe. With every action Eclipse freezes, just showing the flickering progress bar. When I--after some time--kill the Plink process, EGit proceeds and seems to be successful.
I also created a thread dump of my Eclipse during freeze, but do not want it to publically submit here. Can you contact me by E-Mail, just google my name.
Ciao
Franz
Previous Topic:What are the default configuration for gc
Next Topic:Ability to pull from multiple repos seems to have been removed
Current Time: Thu Apr 02 23:37:12 GMT 2020
Powered by FUDForum. Page generated in 0.03963 seconds
