Home » Newcomers » Newcomers » SWTBOt : Extrenal RCP application got launched but crashed(External RCP application launched but crashed using SWTBot Test recorder)
SWTBOt : Extrenal RCP application got launched but crashed [message #1814178] Thu, 05 September 2019 10:21
govind singh is currently offline govind singhFriend
Hi Team,
The application is developed on RCP architecture using SWT controls.
I was trying to automate this application using SWTBot.
I set the Target Platform to launch this application and selected 'Record Test scenario on another eclipse/RCP...' option.
Set the configuration properly when configuration page launched.
When I clicked to RUN button, The app launhed but crashed immediately and throws the below error:
Please help resolve this issue:
!SESSION 2019-09-05 17:54:24.648 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.8.0_102
Framework arguments: -product com.ubs.pmr.launchpad.product.launchpad
Command-line arguments: -product com.ubs.pmr.launchpad.product.launchpad -data C:\UBS\oxygen_wk29/../runtime-TestRecorderBasicDialog -dev file:C:/UBS/oxygen_wk29/.metadata/.plugins/org.eclipse.pde.core/Test Recorder Basic Dialog/dev.properties -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.equinox.simpleconfigurator 4 0 2019-09-05 17:54:28.686
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.equinox.internal.simpleconfigurator.Activator.start() of bundle org.eclipse.equinox.simpleconfigurator.
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:800)
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:729)
at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:933)
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:309)
at org.eclipse.osgi.container.Module.doStart(Module.java:581)
at org.eclipse.osgi.container.Module.start(Module.java:449)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1634)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1614)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1585)
at org.eclipse.osgi.container.SystemModule.startWorker(SystemModule.java:264)
at org.eclipse.osgi.container.SystemModule.start(SystemModule.java:188)
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:383)
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:402)
at org.eclipse.osgi.launch.Equinox.start(Equinox.java:115)
at org.eclipse.core.runtime.adaptor.EclipseStarter.startup(EclipseStarter.java:326)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:239)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:659)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:595)
at org.eclipse.equinox.launcher.Main.run(Main.java:1501)
at org.eclipse.equinox.launcher.Main.main(Main.java:1474)
Caused by: java.lang.IllegalStateException: The System Bundle was updated. The framework must be restarted to finalize the configuration change
at org.eclipse.equinox.internal.simpleconfigurator.ConfigApplier.install(ConfigApplier.java:80)
at org.eclipse.equinox.internal.simpleconfigurator.SimpleConfiguratorImpl.applyConfiguration(SimpleConfiguratorImpl.java:192)
at org.eclipse.equinox.internal.simpleconfigurator.SimpleConfiguratorImpl.applyConfiguration(SimpleConfiguratorImpl.java:207)
at org.eclipse.equinox.internal.simpleconfigurator.Activator.start(Activator.java:61)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:779)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1)
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:772)
... 25 more
Root exception:
!ENTRY org.eclipse.osgi 4 0 2019-09-05 17:54:28.689
!MESSAGE Bundle org.eclipse.equinox.simpleconfigurator_1.2.1.v20180131-1435 [2] is not active.
!ENTRY org.eclipse.swtbot.generator 2 0 2019-09-05 17:54:28.693
!MESSAGE Could not resolve module: org.eclipse.swtbot.generator [3]
Unresolved requirement: Require-Bundle: org.eclipse.ui
!ENTRY org.eclipse.osgi 4 0 2019-09-05 17:54:28.701
!MESSAGE Application error
!STACK 1
java.lang.IllegalStateException: Unable to acquire application service. Ensure that the org.eclipse.core.runtime bundle is resolved and started (see config.ini).
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:78)
Previous Topic:If Statement
Next Topic:Raspbian Install Problem
Current Time: Thu Aug 13 06:50:12 GMT 2020
Powered by FUDForum. Page generated in 0.03849 seconds
