Home » Eclipse Projects » Kura » kura and swagger codegen issues
kura and swagger codegen issues [message #1811187] Wed, 28 August 2019 06:35
I'm using swagger to generate interfaces and models for my endpoints in kura, however the generated "@JsonProperty("fieldName")" annotation (from "com.fasterxml.jackson.annotation") in the model class does not seem to work.
My generated endpoint interface:
 @Path("/contact")
@Api(description = "the contact API")
@javax.annotation.Generated(value = "io.swagger.codegen.languages.JavaJAXRSSpecServerCodegen", date = "2019-08-28T13:04:01.544+03:00")
public interface ContactApi {
    @POST
    @Produces({ "application/json" })
    @ApiOperation(value = "Add new contact", notes = "", tags={  })
    @ApiResponses(value = {
        @ApiResponse(code = 200, message = "succsseful operation", response = Void.class) })
    void contactPost(@Valid Contact contact);
My generated model:
public class Contact  implements Serializable {
  private @Valid String [b]contactId[/b] = null;
  @ApiModelProperty(value = "")
  @JsonProperty("[b]contact_id[/b]")
  public String getContactId() {
    return [b]contactId[/b];
  public void setContactId(String contactId) {
    this.contactId = contactId;
When someone calls this endpoint with json that has "contact_id" field, it should be mapped to "contactId", but this does not work, so whichever service is doing the mapping does not seem to read the "@JsonProperty" annotation.
Has anyone tried to use the "@JsonProperty" annotation and had it working? Is it possible that "com.eclipsesource.jaxrs.jersey-min_2.22.2" might not support jackson annotations?
[Updated on: Thu, 29 August 2019 00:45] by Moderator
Previous Topic:firewall warning
Next Topic:Connection loss after uninstalling dhcpcd5
Current Time: Sat Jul 12 12:18:10 EDT 2025
Powered by FUDForum. Page generated in 0.11716 seconds
