Re: How to use empty redirectable catalogs for projects [message #1811112 is a reply to message #1811103] |
Tue, 27 August 2019 06:30 |
torsten piotraschke Messages: 16 Registered: October 2017 |
Thank you for your quick reply, Ed.
Quote:Are your repositories private? I.e., does access require authentication? I added some help for that in the wiki:
https://wiki.eclipse.org/Eclipse_Oomph_Authoring#Accessing_Setups_that_Require_Authentication
Yes, I will look into the link.
Quote:Unfortunately what you show will not work because the source and target of a redirection must both be absolute URIs.
I read about it, I also tried using file:/data/user/eclipse-installer/setups, file://data/user/eclipse-installer/setups and file:///data/user/eclipse-installer/setups, but it didn't work either.
Quote:https://wiki.eclipse.org/Eclipse_Oomph_Authoring#Automation_and_Specialization_with_Configurations
With such a thing, you could just drag and drop the Configuration link onto the installer. If your Configuration properly specifies an absolute URI that refers to your Project setup, ideally via a URI that navigates through the Project Catalog, the necessary redirection to redirect the redirectable Project Catalog to your Project Catalog will be done automatically (at least that's how it works when I last tested it).
Thanks I will also have a look at that.
FUDForum. Page generated in 0.04032 seconds
