Home » Eclipse Projects » RCP Testing Tool » AUT not detected by rcptt.runner 2.4.2(Unable to launch aut using rcptt runnner 2.4.2 )
AUT not detected by rcptt.runner 2.4.2 [message #1810992] Fri, 23 August 2019 02:50 Go to next message
I am trying to execute my tests using rcptt runner command. I get the below error:
AUT-0:Launching
AUT-0:Product: null
AUT-0:Application: null
AUT-0:Architecture: x86_64
64bit arch is selected because AUT uses launcher library
"plugins/org.eclipse.equinox.launcher.win32.win32.x86_64_1.1.551.v20171108-1834" specified in config file: eclipse.ini
D:\aut-SDP-0: AUT arguments: -os ${target.os} -arch ${target.arch} -consoleLog
AUT-0: Launch failed. Reason: Failed to launch AUT since there is no Product and Application ID found.
AUT-0: For more information check AUT output at 'D:\rcpttRunnerWorkspace\aut-SDP-0_console.log'
Failed to launch AUT:AUT-0: Launch failed. Reason: Failed to launch AUT since there is no Product and Application ID found.
But when i tried to add the aut path in rcptt 2.4.2, it gets identified and gets added.
Any pointers to solving the issue will be helpful.
Thanks.
Re: AUT not detected by rcptt.runner 2.4.2 [message #1814499 is a reply to message #1810992] Thu, 12 September 2019 05:26 Go to previous messageGo to next message
Even I am facing this issue on RCPTT 2.4.2.In fact clicking the finish button while configuring AUT is not possible
When i tried to add the same aut path using older versions of RCPTT,it is succesful
any helpwill be appreciated
Re: AUT not detected by rcptt.runner 2.4.2 [message #1814531 is a reply to message #1814499] Thu, 12 September 2019 14:04 Go to previous messageGo to next message
Hi Sangeeta,
Your issue might be because of the equinox launcher. My experience has been, equinox launcher of RCPTT has to be same version as that of AUT equinox launcher.
[Updated on: Fri, 13 September 2019 02:11] by Moderator
Re: AUT not detected by rcptt.runner 2.4.2 [message #1814550 is a reply to message #1814531] Fri, 13 September 2019 01:41 Go to previous message
Thanks !
I will check this
Previous Topic: AUT does not have focus during test execution
Next Topic:Eclipse Kepler (4.3) and RCPTT
Current Time: Sun Nov 02 05:13:23 EST 2025
Powered by FUDForum. Page generated in 0.21925 seconds
