Home » Newcomers » Newcomers » The JAR file M2_REPO\org\testng\testng\6.9\testng-6.9.6.jar has no source attachment(Jar fiel has no source file message while debugging.)
The JAR file M2_REPO\org\testng\testng\6.9\testng-6.9.6.jar has no source attachment [message #1810989] Fri, 23 August 2019 04:43 Go to next message
Man Kan is currently offline Man KanFriend
I am trying to debug a code but getting the message
"The JAR file M2_REPO\org\testng\testng\6.9\testng-6.9.6.jar has no source attachment"
Can someone please help me? I am not able to resolve it. This is stopping me from debugging. I tried to search in forum but didn't resolve my issue. I am new to eclipse, so i guess it must be a basic question.
Please see attachment for the screenshot.
When i click on attach source, it is giving pop-up to enter location variable path. I am not sure what it is.
  • Attachment: Doc2.docx
    (Size: 416.42KB, Downloaded 41 times)
[Updated on: Fri, 23 August 2019 04:51]
Report message to a moderator
Re: The JAR file M2_REPO\org\testng\testng\6.9\testng-6.9.6.jar has no source attachment [message #1810997 is a reply to message #1810989] Fri, 23 August 2019 08:53 Go to previous messageGo to next message
You have to point it at a jar or folder that contains the corresponding *.java files.
Re: The JAR file M2_REPO\org\testng\testng\6.9\testng-6.9.6.jar has no source attachment [message #1811006 is a reply to message #1810997] Fri, 23 August 2019 13:35 Go to previous messageGo to next message
I don't know how to do it. Can you please help?
I did the following way
I download the testng6.9 jar files(there are like 8 jar fles) and then went to java build path in eclipse.
Went to libraries tab and clicked on Add Library and selected the downloaded 8 testng6.9 jar files and clicked ok.
Please see the screenshot in attached doc3 document.
Still getting the message.
Am i doing the right way. Please help.
  • Attachment: Doc3.docx
    (Size: 182.29KB, Downloaded 37 times)
[Updated on: Fri, 23 August 2019 13:50]
Re: The JAR file M2_REPO\org\testng\testng\6.9\testng-6.9.6.jar has no source attachment [message #1811070 is a reply to message #1811006] Mon, 26 August 2019 13:33 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin DahyabhaiFriend
Please stop putting your images into Word documents. Attach them directly.
Do you have the sources for those jars in any form locally?
Nitin Dahyabhai
Eclipse Web Tools Platform
[Updated on: Mon, 26 August 2019 13:33]
Re: The JAR file M2_REPO\org\testng\testng\6.9\testng-6.9.6.jar has no source attachment [message #1811320 is a reply to message #1811070] Fri, 30 August 2019 17:42 Go to previous messageGo to next message
I have downloaded the testng6.9 jar files locally. I am not sure if they can be called as source files.
[Updated on: Fri, 30 August 2019 17:44]
Re: The JAR file M2_REPO\org\testng\testng\6.9\testng-6.9.6.jar has no source attachment [message #1811328 is a reply to message #1811320] Sat, 31 August 2019 05:13 Go to previous messageGo to next message
If the jar contains *.java files and not just *.class files, then it has source files, otherwise it doesn't.
Re: The JAR file M2_REPO\org\testng\testng\6.9\testng-6.9.6.jar has no source attachment [message #1811335 is a reply to message #1811328] Sat, 31 August 2019 14:16 Go to previous messageGo to next message
They all are 8 jar files. I don't know how to view the content of each and every jar file.
[Updated on: Sat, 31 August 2019 14:29]
Re: The JAR file M2_REPO\org\testng\testng\6.9\testng-6.9.6.jar has no source attachment [message #1814006 is a reply to message #1811335] Sun, 01 September 2019 04:44 Go to previous message
https://www.google.com/search?q=view+contents+of+jar+windows
Previous Topic:Building Legacy Mars project
Next Topic:Đánh giá Asus Rog Claymore: thiết kế đẹp, gõ sướng, giá cao
Current Time: Fri Jan 24 08:02:23 GMT 2020
Powered by FUDForum. Page generated in 0.02793 seconds
