Home » Newcomers » Newcomers » Eclipse with Oxygen 3(JRE troubles)
Eclipse with Oxygen 3 [message #1810980] Thu, 22 August 2019 23:43 Go to next message
Alejandro Garay is currently offline Alejandro GarayFriend
The thing is that i'm doing everything to run an ant project but it ends with the error.
"JRE version less than 1.8 is not supported". i even changed all the jdk to 12.x and jre to the last build (8.221) and dstill not working. if somebody can please help me reconfigure eclipse and variable environments i'll be thankfully.
Re: Eclipse with Oxygen 3 [message #1810984 is a reply to message #1810980] Fri, 23 August 2019 01:31 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin DahyabhaiFriend
How are they configured now?
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: Eclipse with Oxygen 3 [message #1810986 is a reply to message #1810984] Fri, 23 August 2019 03:49 Go to previous message
I believe that Oxygen will not (easily) run itself on Java 12, and will not recognize a Java 12 JDK as being a JDT. If you want to run Oxygen, you're probably best to also install Java 1.8 for that purpose.
Ed Merks
Previous Topic:2019 Silent install
Next Topic:Problem with eclipse 2019 ide latest update
Current Time: Mon Sep 21 20:31:59 GMT 2020
Powered by FUDForum. Page generated in 0.02969 seconds
