Home » Newcomers » Newcomers » Scout Explorer and setting up a connection to MySQL
Scout Explorer and setting up a connection to MySQL [message #1810884] Wed, 21 August 2019 10:04 Go to next message
Faruk Caglar is currently offline Faruk CaglarFriend
I just started with Eclipse Scout in order to evaluate if this could be the right framework for a new project. I have installed Eclipse IDE 2019-06 (4.12.0) and also the Eclipse Scout SDK (9.0.0.018_Simrel_2019_06) and went through the hello world tutorial as well as the Beginners Guide. I now just wanted to connect to a MySQL schema. Searching the internet for help was unfortunately not really successful. I found, that there should be a Scout Explorer, in which there is a technology part where I could change to a MySQL jdbc connection. Unfortunately the Scout perspective is not available in my installation and I have no idea why.
Could you give me a hint what I have to do?
Thanks in advance
Re: Scout Explorer and setting up a connection to MySQL [message #1810933 is a reply to message #1810884] Thu, 22 August 2019 09:22 Go to previous messageGo to next message
Maybe you should install the Scout IDE:
https://www.eclipse.org/downloads/packages/release/2019-06/r/eclipse-ide-scout-developers
You can do that with the installer as well.
It's generally best to ask about Scout on their specific forum:
https://www.eclipse.org/forums/index.php?t=thread&frm_id=174
Ed Merks
Re: Scout Explorer and setting up a connection to MySQL [message #1810938 is a reply to message #1810933] Thu, 22 August 2019 10:11 Go to previous message
thanks for the suggestion. I tried it, but unfortunately it is the same: No Scout Exporer/Scout perspective available.
I will post my question in the Scout forum.
Thanks!
Previous Topic:Multiple IDE instances
Next Topic:AMP/AMF counterpart for DES (Discrete-Event Simulation) models
Current Time: Tue Sep 22 02:11:22 GMT 2020
Powered by FUDForum. Page generated in 0.03695 seconds
