Home » Archived » Jubula » Error is coming on RCP AUT integration for Jubula
Error is coming on RCP AUT integration for Jubula [message #1810883] Wed, 21 August 2019 10:04 Go to next message
Ruchi Bhasin is currently offline Ruchi BhasinFriend
We were getting a Jubula error that it could not be fully started because of a missing class (org.eclipse.e4.ui.model.application.ui.MUIElement cannot be found by org.eclipse.jubula.rc.rcp.e4.swt_5.0.0.201705050842).
I am not getting plugin in AUT as per steps below;
https://help.eclipse.org/neon/index.jsp?topic=/org.eclipse.jubula.client.ua.help/content/html/userManual/toolkit/rcpAUT/setting-up-an-rcp-aut-for-testing.html
Re: Error is coming on RCP AUT integration for Jubula [message #1811119 is a reply to message #1810883] Tue, 27 August 2019 07:09 Go to previous messageGo to next message
Marvin Mueller is currently offline Marvin MuellerFriend
Hello, can you please describe how your RCP application is set up?
Which version of the eclipse platform you are using?
Are you using JavaFX as frontend in your RCP application?
best regards
Marvin Mueller
Re: Error is coming on RCP AUT integration for Jubula [message #1811290 is a reply to message #1811119] Fri, 30 August 2019 07:24 Go to previous messageGo to next message
Hi Marvin,
Thanks for the reply. We are using Eclipse oxygen version. I have sent rest of the queries to development team. Can you please help me to know which version of jubula jar is compatible with Eclipse Oxygen?
Ruchi
Re: Error is coming on RCP AUT integration for Jubula [message #1814084 is a reply to message #1811290] Tue, 03 September 2019 09:18 Go to previous messageGo to next message
Hello Ruchi,
Please see the related Bug fix [1]. So we have fixed it for jubula 5.0.0, you can simple use the attachment from the Bug.
Using Jubula version 6 and above should definitely work.
best regards
Marvin Mueller
[1] https://bugs.eclipse.org/bugs/show_bug.cgi?id=518547
Re: Error is coming on RCP AUT integration for Jubula [message #1814092 is a reply to message #1814084] Tue, 03 September 2019 12:49 Go to previous messageGo to next message
Thanks Marvin! I am not allowed to download from the eclipse page directly. What is the direct url for installing jubula 6.0 version or fixed version from eclipse marketplace or install new software option? When I open through Oxygen - http://download.eclipse.org/releases/oxygen, I dont see these versions but only 5.0.0.201705050842.
Is it possible for you to upload version at http://download.eclipse.org/releases/oxygen,
[Updated on: Tue, 03 September 2019 12:56]
Report message to a moderator
Re: Error is coming on RCP AUT integration for Jubula [message #1814358 is a reply to message #1810883] Tue, 10 September 2019 07:16 Go to previous message
On the Bugticket, there is only the fixed RCP accessors(that one that must be installed into your Application). I can not upload this to the releases website.
Previous Topic:problems with checktextwithcellspec in Jubula 8.7.1.046
Next Topic:Error while running under embedded AUT agent
Current Time: Tue Dec 03 00:25:43 GMT 2024
Powered by FUDForum. Page generated in 0.03575 seconds
