Home » Modeling » TMF (Xtext) » Content assist test with import
Content assist test with import [message #1810664] Thu, 15 August 2019 09:25 Go to next message
I'm trying to create a content assist test but the test does not take into account the imported files. I found that xtext is loading both resources but not doing the linking, and thus my autocomplete (which depends on the linking) fails. How can I force the linking of the resources in the test. Below is the failing test. Any ideas of what can be wrong?
@RunWith(XtextRunner)
@InjectWith(MappingUiInjectorProvider)
class PathContentAssistTest extends AbstractContentAssistTest {
    @Inject
    ResourceSetManager resourceSetManager
    protected var ResourceSet testModel
	val mapModel = ''' my model (..) '''
	@Test
	def void testComplete() {
		val model = '''
		SimpleMapping 1.0.0
		import "MAP.model"
		VirtualMappingWithAggregationTest for input @MAP.OtherOutputEntity
		output @MAP.VirtualModelOutputEntity
		 with @MAP.OtherOutputEntity as myInput {
		 	outputBoolean = myInput.otherBoolean.outputBoolean
		newBuilder()
			.append(model)
			.assertTextAtCursorPosition(model.indexOf("otherBoolean"), "\"Column\"", "\"otherBoolean\"", "\"otherDate\"")
	def addResource(XtextResourceSet set, String modelName, String modelContent) {
		val inputStream = new StringInputStream(modelContent)
		val resource = set.createResource(URI::createURI(modelName))
		resource.load(inputStream, null)
	override protected initializeTypeProvider(XtextResourceSet set) {
		addResource(set, "test.model", mapModel)
		super.initializeTypeProvider(set)
Re: Content assist test with import [message #1810669 is a reply to message #1810664] Thu, 15 August 2019 12:37 Go to previous messageGo to next message
An example for that can be found under https://github.com/itemis/itemis-blog/blob/combining-emf-models-with-xtext-dsls/org.eclipse.xtext.example.fowlerdsl.ui.tests/src/org/eclipse/xtext/example/fowlerdsl/ui/tests/StatemachineContentAssist2Test.xtend
Re: Content assist test with import [message #1810676 is a reply to message #1810669] Thu, 15 August 2019 15:11 Go to previous message
Thanks for the example, I managed to adapt it to my needs.
Edmundo López Bóbeda
Previous Topic:Mwe2Launcher - Cannot create a resource with ANT
Next Topic:Code generation
Current Time: Wed Apr 23 12:02:50 EDT 2025
Powered by FUDForum. Page generated in 0.03598 seconds
