Home » Newcomers » Newcomers » ctrl + shift + r, searching with contained letters
ctrl + shift + r, searching with contained letters [message #1810650] Thu, 15 August 2019 07:12 Go to next message
Isagani Pumar is currently offline Isagani PumarFriend
When I do ctrl + shit + r to search for my files, I'll only be able to search a file starting from their first letters and so on. So if I get a file's name wrong, it won't show up in the search results. How can I change it so I can have the search results with contained words rather than specific words starting from the first letter?
Example:
I type in "Command"
It'll show me all the files with the starting word "Command" and so on.
Now let's say one of the files is called "CommandDeveloper"
if I try to search "Developer"
It will NOT show "CommandDeveloper" rather, it will show any file
name with the beginning word "Developer" and so on after that.
I want to change that, so when I search "Developer" it will find ALL files with the word containing "Developer" just like how a search system is supposed to work.
  • Attachment: dev.PNG
    (Size: 10.12KB, Downloaded 29 times)
Re: ctrl + shift + r, searching with contained letters [message #1810661 is a reply to message #1810650] Thu, 15 August 2019 12:28 Go to previous message
The dialog shows right at the top that * and ? can be used for "patterns". So *Developer should to the trick. I often use this to find *.ecore or *.setup.
Ed Merks
Previous Topic:Can't install Glassfish Tools
Next Topic:CSS color-attribute preview swatches show up randomly
Current Time: Fri Aug 07 10:33:42 GMT 2020
Powered by FUDForum. Page generated in 0.02457 seconds
