Home » Eclipse Projects » Mita » Example of Configuration reading from SD card(Is there any example on how to read data from an SD card?)
Example of Configuration reading from SD card [message #1810589] Wed, 14 August 2019 03:25 Go to next message
Tim Grossmann is currently offline Tim GrossmannFriend
Is there any example on how to read data from a file on an SD card?
Looking at the docs, there is no example given which would be very helpful.
Are there any examples of Mita files online?
The current code I have looks like this:
setup sd : SDCard {
	var reader : string = resumingTextRead("setup.conf", 512);
every 5 seconds {
    let value : string = sd.reader.read();
    println(value);
In the end I want to read out a config file on an SD card and populate the WIFI credentials and MQTT credentials with.
Is that possible?
Thank you
Re: Example of Configuration reading from SD card [message #1811280 is a reply to message #1810589] Fri, 30 August 2019 05:38 Go to previous messageGo to next message
Simon Wegendt is currently offline Simon WegendtFriend
configuring the XDKs WLAN from SD-Card is not currently possible with Mita.
Best Regards,
Simon.
Re: Example of Configuration reading from SD card [message #1829108 is a reply to message #1810589] Thu, 25 June 2020 09:20 Go to previous message
Vitali --- is currently offline Vitali ---Friend
is there maybe now a possibility to read Configuration from SD-Card with mita?
For example
HonoMqtt, Wifi, etc.
Vitali
Previous Topic:Heap Issue when using EclipseMitaApplication with XDK
Current Time: Sat Jul 11 09:31:33 GMT 2020
Powered by FUDForum. Page generated in 0.02207 seconds
