Home » Modeling » TMF (Xtext) » How to disable Parser-Markers in Project Explorer
How to disable Parser-Markers in Project Explorer [message #1810343] Thu, 08 August 2019 14:17 Go to next message
Konrad Jünemann is currently offline Konrad JünemannFriend
Member
for my DSL I would like to implement the option to disable the creation of any problem markers for found problems in the problems view and project explorer. For the problems view, I can just use a filter in the UI. However, no such option exists for the project explorer.
How would I disable the generation of problem markers for my language? Ideally, the errors would still exist, but not shown, so that parsing and validation is still performed.
Konrad
Re: How to disable Parser-Markers in Project Explorer [message #1810352 is a reply to message #1810343] Thu, 08 August 2019 16:27 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
hi, i wonder what your actual usecase for that. maybe the solution you have in mind is the wrong one.
markers are created by org.eclipse.xtext.ui.editor.validation.MarkerCreator.createMarker(Issue, IResource, String)
Twitter : @chrdietrich
Re: How to disable Parser-Markers in Project Explorer [message #1810356 is a reply to message #1810352] Thu, 08 August 2019 18:13 Go to previous messageGo to next message
Member
Hi Christian,
I guess the case is special. We use two separate DSLs in our project, a business DSL A and a technical DSL B. A files compile to B files, which are then compiled to all sorts of SQL scripts and so on. This approach is kinda similar to XTend -> Java -> Bytecode.
The actual build process is standalone, though. So during the typical business day, a user *rarely* requires the later files (of type B or SQLs), although occasions arise where you would like to look into those.
However, our infrastructure is "a little" weak in the context I am working in. In order to cope with this, I have to keep the number of generated files to an absolute minimum as a simple eclipse-refresh (unrelated to XTtext) takes multiple seconds to complete (CPU power is fine). So, I build a feature to turn off generation of B files (and SQL files), as typically you don't need those. I used the IShouldGenerate approach, as recommended by you in another thread.
However, as some (but few) B files are created manually *and* relate to generated B files, there will always be errors due to unresolved B-references. I don't want users to bother with those if they are business level users, who will at most edit A-files.
My ideal solution would be to generate *all* B files or to not allow not-generated B files to refer to generated B files, but we are not quite there.
OK, wall of text. I am eager to hear if you have any other recommendations - otherwise thank you a lot for your hint!
Konrad
Re: How to disable Parser-Markers in Project Explorer [message #1810369 is a reply to message #1810356] Thu, 08 August 2019 19:11 Go to previous messageGo to next message
Depending on what the problem with generation performance is you could consider generation stubs only as Xtend does it for methods with errors
Re: How to disable Parser-Markers in Project Explorer [message #1810406 is a reply to message #1810369] Fri, 09 August 2019 15:53 Go to previous message
Member
Great idea, thank you. I will try it out.
Your hint with the MarkerCreator works perfectly, too.
Thanks!
Previous Topic:XText Web. How finds ACE the Language Server?
Next Topic:Maven build issues
Current Time: Sat Sep 21 00:51:07 GMT 2024
Powered by FUDForum. Page generated in 0.03296 seconds
