Home » Eclipse Projects » 4DIAC - Framework for Distributed Industrial Automation and Control » boot file throw error
boot file throw error [message #1810326] Thu, 08 August 2019 06:07 Go to next message
joy woo is currently offline joy wooFriend
Member
INFO: T#1: FORTE is up and running
INFO: T#126: Using provided bootfile location: D:\test\forte-incubation_1.10.2\bin\win32\src\Debug\forte.fboot
INFO: T#146: Boot file D:\test\forte-incubation_1.10.2\bin\win32\src\Debug\forte.fboot opened
ERROR: T#167: Boot file error. DEV_MGR says error is INVALID_DST
ERROR: T#180: Boot file command could not be executed. Line: 1: <Request ID="0
INFO: T#195: Closing bootfile
INFO: T#200: CWin32SocketInterface: Opening TCP-Server connection at: localhost:61499
attachment is the forte.fboot file
  • Attachment: forte.fboot
    (Size: 46.61KB, Downloaded 11 times)
Re: boot file throw error [message #1810350 is a reply to message #1810326] Thu, 08 August 2019 16:16 Go to previous messageGo to next message
Alois Zoitl is currently offline Alois ZoitlFriend
I don't see anything obviouse. I'll have to debug deeper into it.
Re: boot file throw error [message #1810370 is a reply to message #1810350] Thu, 08 August 2019 19:37 Go to previous messageGo to next message
I spent some time in the debugger now and finally also looked at it in an hex editor. It looks like there is some unicode character at the first position of this file. This should not be there. Have you edited this file with some application?
Re: boot file throw error [message #1810384 is a reply to message #1810370] Fri, 09 August 2019 08:35 Go to previous messageGo to next message
Member
Actully even if i use the directly export file from 4diac-ide and the downloaded forte.exe the same error, i see the file format is utf-8, so which words are unicode?
    (Size: 6.08KB, Downloaded 10 times)
Re: boot file throw error [message #1810386 is a reply to message #1810384] Fri, 09 August 2019 08:45 Go to previous messageGo to next message
Member
sorry, the file generated from 4diac ide is ok, just now its's pointing to the enviroment virable. why the first file is not ok?
Re: boot file throw error [message #1810387 is a reply to message #1810386] Fri, 09 August 2019 08:54 Go to previous messageGo to next message
Member
i find the reason, the file should be ANSI file type, utf-8 is not ok,
thank you for your support, Mr. Zoitl, have a nice weekend!
Re: boot file throw error [message #1810396 is a reply to message #1810387] Fri, 09 August 2019 11:35 Go to previous messageGo to next message
sorry for the late reply. Yes the problem with anything then a basic asci text file is that it has a prefix. we currently are not able to handle such a prefix.
Re: boot file throw error [message #1810479 is a reply to message #1810396] Mon, 12 August 2019 15:11 Go to previous messageGo to next message
Member
that means we can't use unicode character for FB name and resource name , is that right ?
Re: boot file throw error [message #1810481 is a reply to message #1810479] Mon, 12 August 2019 15:16 Go to previous message
yes but that is currently anyhow not allowed by the standard.
Previous Topic:4DIAC - Composite Function Block
Next Topic:Terminated for publisher and subscriber
Current Time: Mon Feb 17 13:32:36 GMT 2020
Powered by FUDForum. Page generated in 0.05402 seconds
