Home » Eclipse Projects » scout » embedding a PDF document as an object in the html code
embedding a PDF document as an object in the html code [message #1810287] Tue, 06 August 2019 14:35 Go to next message
Krzysztof Leja is currently offline Krzysztof LejaFriend
Member
As in the title: I would like to embed a PDF document in the form.
The PDF document is dynamically generated in the client module and stored in the instance of the BinaryResource class.
In the form I created a field inheriting from AbstractHtmlField, where in the execInitField () method I would like to load a PDF document as below in the example:
public class PrintField extends AbstractHtmlField {
	protected void execInitField() {
		try {
			BinaryResource pdfContent = TableExporter.getAsPDF(parentTable);
			setValue("object:<center><object data=\"" + pdfContent.getFilename() + "\" type=\"application/pdf\" width=\"100%\" height=\"100%\"><p>No PDF document</p></object></center>");
		} catch (Exception e) {
			e.printStackTrace();
Question:
How to correctly set the "data" attribute of the Object's tag so that a PDF document stored in the BinaryResource automatically loads in it?
Re: embedding a PDF document as an object in the html code [message #1810308 is a reply to message #1810287] Wed, 07 August 2019 12:53 Go to previous message
Member
In the meantime, I was able to solve my problem.
I added the "BinaryResource:" prefix to the data attribute and passed the BinaryResource handler to the addAttachment method as follows:
		try {
			addAttachment(pdfContent);
			setValue("object:<center><object data=\"binaryResource:" + pdfContent.getFilename() + "\" type=\"application/pdf\" width=\"100%\" height=\"100%\"><p>No PDF document</p></object></center>");
Now it works :-)
I also discovered that an alternative effect can be obtained by using an AbstractBrowserField field like this:
public class BrowseField extends AbstractBrowserField {
				setBinaryResource(pdfContent);
			protected boolean getConfiguredScrollBarEnabled() {
			          return true;
[Updated on: Wed, 07 August 2019 12:59]
Report message to a moderator
Previous Topic:Image blocked from loading - CSP configuration parameters not taken into account ?
Next Topic:Registration Form
Current Time: Fri Jan 22 01:07:45 GMT 2021
Powered by FUDForum. Page generated in 0.01541 seconds
