Home » Modeling » EMF » [2.14] XML documentation language
[2.14] XML documentation language [message #1810190] Fri, 02 August 2019 14:17 Go to next message
Jonathan Laval is currently offline Jonathan LavalFriend
I notice that when I load a model from XSD schema defining several documentation blocks with different languages, the EMF model concatenates all the messages and it is no longer possible to retrieve the message associated with the language.
is there a way to get the good documentation ?
thanks
jo
Re: [2.14] XML documentation language [message #1810192 is a reply to message #1810190] Fri, 02 August 2019 15:45 Go to previous messageGo to next message
Your question is a bit context-free. Do you mean when you convert the XML Schema to an Ecore model how to get the information that came originally from the XSD? No doubt all the documentation is joined and place under a single documentation annotation so no, there is no way to recover the original XML Schema details for this.
Ed Merks
Re: [2.14] XML documentation language [message #1817254 is a reply to message #1810192] Tue, 19 November 2019 11:05 Go to previous messageGo to next message
Mubeen Aslam is currently offline Mubeen AslamFriend
Hello Community,
I am facing a problem and i need your help. I created a class diagram in the modeling tool of Eclipse. I want to check the java code built at the back of my class diagram. How can i view the java code and XML code for my class diagram?
Re: [2.14] XML documentation language [message #1817875 is a reply to message #1817254] Mon, 02 December 2019 05:05 Go to previous message
This question seems unrelated to this thread. The generated Java code will be in some project and you can use the Package Explorer view to view it and open the *.java files to view them.
Ed Merks
Previous Topic:[CDO] Repository checkouts not visible in Project Explorer
Next Topic:JSON to UML model conversion
Current Time: Sat Feb 27 00:20:24 GMT 2021
Powered by FUDForum. Page generated in 0.02133 seconds
