Home » Modeling » EMF » EMF eCore .diagram files are not saved in EMF Compare API(EMF eCore .diagram files are not saved in EMF Compare API)
EMF eCore .diagram files are not saved in EMF Compare API [message #1809900] Thu, 25 July 2019 12:37 Go to next message
Mallikarjun Reddy is currently offline Mallikarjun ReddyFriend
Hi Team,
we developed the .diagram files from EMF eCore functionality with org.eclipse.emf.transaction management functionality.
We unable to save the .diagram files in Compare API using the merge functionality.
We are getting the below Exception
java.lang.IllegalStateException: Cannot modify resource set without a write transaction
at org.eclipse.emf.transaction.impl.TransactionChangeRecorder.assertWriting(TransactionChangeRecorder.java:349)
at org.eclipse.emf.transaction.impl.TransactionChangeRecorder.appendNotification(TransactionChangeRecorder.java:303)
at org.eclipse.emf.transaction.impl.TransactionChangeRecorder.processObjectNotification(TransactionChangeRecorder.java:285)
at org.eclipse.emf.transaction.impl.TransactionChangeRecorder.notifyChanged(TransactionChangeRecorder.java:241)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:424)
at com.intervoice.gtf.tc.impl.CalculateValueTypeImpl.setExpr(CalculateValueTypeImpl.java:130)
at com.intervoice.gtf.tc.impl.CalculateValueTypeImpl.eSet(CalculateValueTypeImpl.java:161)
at org.eclipse.emf.compare.utils.ReferenceUtil.safeESet(ReferenceUtil.java:183)
at org.eclipse.emf.compare.merge.AttributeChangeMerger.changeValue(AttributeChangeMerger.java:329)
at org.eclipse.emf.compare.merge.AttributeChangeMerger.accept(AttributeChangeMerger.java:72)
at org.eclipse.emf.compare.merge.AbstractMerger.copyDiff(AbstractMerger.java:794)
at org.eclipse.emf.compare.merge.AbstractMerger.copyLeftToRight(AbstractMerger.java:817)
at org.eclipse.emf.compare.merge.BatchMerger.copyAllLeftToRight(BatchMerger.java:150)
at com.intervoice.gtf.compare.mergeviewer.ContentMergeViewer.copyLeftToRight(ContentMergeViewer.java:711)
at com.intervoice.gtf.compare.mergeviewer.ContentMergeViewer.copy(ContentMergeViewer.java:218)
at org.eclipse.compare.contentmergeviewer.ContentMergeViewer$3.run(ContentMergeViewer.java:940)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:476)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:568)
at org.eclipse.jface.action.ActionContributionItem.lambda$5(ActionContributionItem.java:439)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:89)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4131)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1055)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3944)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3547)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1173)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:339)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1062)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:156)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:636)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:563)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:151)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:155)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:137)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:107)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:400)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:659)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:595)
at org.eclipse.equinox.launcher.Main.run(Main.java:1501)
at org.eclipse.equinox.launcher.Main.main(Main.java:1474)
Re: EMF eCore .diagram files are not saved in EMF Compare API [message #1809917 is a reply to message #1809900] Thu, 25 July 2019 16:09 Go to previous message
You also opened this:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=549563
You seems to have something special installed, com.intervoice.gtf.compare, so it's hard to comment on what that might be doing.
Ed Merks
Previous Topic:Get IllegalValueException when opening model with Ecore Model Editor
Next Topic:MetaModelServiceRegistry initialization failed
Current Time: Tue Apr 16 19:41:00 GMT 2024
Powered by FUDForum. Page generated in 0.39808 seconds
