Home » Modeling » MoDisco » Cast Errors in a Custom Metamodel
Cast Errors in a Custom Metamodel [message #1809479] Tue, 16 July 2019 13:58 Go to next message
I created a custom metamodel and an instance of it. The metamodel handles some metadata from the KDM metamodel. Specifically, KDMEntity and AbstractStructureElement. I attached the metamodel RMSAS for better understanding.
When I create an instance manually, everything works fine but when I need to open the instance with the reflective ecore model editor, it raises cast errors.
StorableUnitImpl cannot be cast to KDMEntity.
org.eclipse.emf.ecore.xmi.IllegalValueException: Value 'org.eclipse.gmt.modisco.omg.kdm.code.impl.StorableUnitImpl@56479f53
Caused by: java.lang.ClassCastException: org.eclipse.gmt.modisco.omg.kdm.code.impl.StorableUnitImpl cannot be cast to kdm.core.KDMEntity
and
ComponentImpl cannot be cast to AbstractStructureElement
org.eclipse.emf.ecore.xmi.IllegalValueException: Value 'org.eclipse.gmt.modisco.omg.kdm.structure.impl.ComponentImpl@78ca78cd
Caused by: java.lang.ClassCastException: org.eclipse.gmt.modisco.omg.kdm.structure.impl.ComponentImpl cannot be cast to kdm.structure.AbstractStructureElement
I use KDMEntity because I want to represent StorableUnits, ClassUnits and MethodUnits and from the structure package AbstractStructureElement because I want to represent Components and Subsystems.
How can I solve these issues?. What kind of metadata do I should use to avoid casts errors?
Daniel
  • Attachment: RMSAS.png
    (Size: 317.09KB, Downloaded 111 times)
[Updated on: Tue, 16 July 2019 21:48] by Moderator
Re: Cast Errors in a Custom Metamodel [message #1809583 is a reply to message #1809479] Thu, 18 July 2019 10:04 Go to previous messageGo to next message
I changed some things in my project. When I try to run as eclipse runtime and create a new model it raises the follwing error.
Caused by: java.lang.NoClassDefFoundError: org/eclipse/gmt/modisco/omg/kdm/core/provider/KdmEditPlugin
I also changed restriction rules to accesible.
Re: Cast Errors in a Custom Metamodel [message #1809713 is a reply to message #1809583] Sun, 21 July 2019 19:26 Go to previous message
I resolved it by creating the model programmatically.
Previous Topic:Code Generation - Unresolved Reference in GenerateJava.emtl
Next Topic:Unable to get KDM Plugin installed
Current Time: Mon Jun 23 06:19:57 EDT 2025
Powered by FUDForum. Page generated in 0.04144 seconds
