Home » Eclipse Projects » RCP Testing Tool » Get-window regex(Test that a window is opened, name is given as regex)
Get-window regex [message #1809435] Tue, 16 July 2019 03:25 Go to next message
I want to test that after some actions, a window is opened.
The code below doesn't work, I get that the window doesn't exist.
get window "Help - Test"
I tried to give a regex like below, and it still doesn't work:
get window "Help - *"
There is a way to get the latest opened window and then I will check if that is the window I want? Or to get a window by name regex?
Re: Get-window regex [message #1809532 is a reply to message #1809435] Wed, 17 July 2019 10:47 Go to previous message
The following snippet should help:
get window "Help - .*"
A dot is needed in your script.
Please try and let me know if it helps.
Previous Topic:ecl command bug
Next Topic:How to return value by custom command?
Current Time: Sun Apr 20 19:36:50 EDT 2025
Powered by FUDForum. Page generated in 0.02952 seconds
