Home » Eclipse Projects » EclipseLink » Optimization batch reading collection after invalidation
Optimization batch reading collection after invalidation [message #1809365] Mon, 15 July 2019 02:53 Go to next message
Sebastien Tardif is currently offline Sebastien TardifFriend
Any optimization available in EclipseLink that would avoid doing a SQL for each item in the collection having expired children?
You can run the main entry from the class Application, the log will finish with the output below, showing one select for each item in the collection. I'm looking for an existing feature in EclipseLink that could make this not happening. I believe Hibernate can handle that with https://docs.jboss.org/hibernate/orm/3.5/reference/en/html/performance.html#performance-fetching-batch.
If no feature exist to handle that, could you open a feature request?
[EL Fine]: sql: 2019-07-10 18:01:37.248--ServerSession(1837601499)--Connection(17331878)--Thread(Thread[main,5,main])--SELECT ID, FIRSTNAME, LASTNAME FROM ADDRESS WHERE (ID = ?)
bind => [2]
[EL Fine]: sql: 2019-07-10 18:01:37.249--ServerSession(1837601499)--Connection(1311052922)--Thread(Thread[main,5,main])--SELECT ID, FIRSTNAME, LASTNAME FROM ADDRESS WHERE (ID = ?)
bind => [3]
[EL Fine]: sql: 2019-07-10 18:01:37.25--ServerSession(1837601499)--Connection(810576909)--Thread(Thread[main,5,main])--SELECT ID, FIRSTNAME, LASTNAME FROM ADDRESS WHERE (ID = ?)
bind => [4]
[EL Fine]: sql: 2019-07-10 18:01:37.25--ServerSession(1837601499)--Connection(1629759610)--Thread(Thread[main,5,main])--SELECT ID, FIRSTNAME, LASTNAME FROM ADDRESS WHERE (ID = ?)
bind => [5]
[EL Fine]: sql: 2019-07-10 18:01:37.251--ServerSession(1837601499)--Connection(775423528)--Thread(Thread[main,5,main])--SELECT ID, FIRSTNAME, LASTNAME FROM ADDRESS WHERE (ID = ?)
bind => [6]
  • Attachment: Sample.zip
    (Size: 10.67KB, Downloaded 96 times)
Re: Optimization batch reading collection after invalidation [message #1810471 is a reply to message #1809365] Mon, 12 August 2019 14:05 Go to previous message
Chris Delahunt is currently offline Chris DelahuntFriend
Batch fetching can be added to your queries using query hints:
https://www.eclipse.org/eclipselink/documentation/2.5/jpa/extensions/q_batch.htm
Or to the model relationship via annotation:
https://www.eclipse.org/eclipselink/documentation/2.5/jpa/extensions/a_batchfetch.htm
Previous Topic:Passing Collection List to In clause in nativeQuery - EclipseLink
Next Topic:EclipseLink with Java 9+
Current Time: Tue Dec 06 05:38:34 GMT 2022
Powered by FUDForum. Page generated in 0.02446 seconds
