Read out Genmodel file [message #1808552] |
Wed, 26 June 2019 17:37  |
Dimg Cim Messages: 56 Registered: December 2015 |
Member |
Hello, everybody,
there's a way to get all the information from GenModel, even better Xcore Model. I am currently writing a plug-in that renders EMF Model. There I hand over the {Model}Factory, {Model}Package, {Model}ItemAdapterFactory, etc. every time.
I have to set these classes each time for certain XMI files. To make everything generic, I want to set it using GenModel/ XCore Model.
Unfortunately I didn't find anything. In itself it has to work, right? There are some frameworks that use this approach, e.g. Genmodel to Xcore, GenModel to Xtext, etc.
I know there are, but where do I get into the code?
Many greetings
lam
Re: Read out Genmodel file [message #1808569 is a reply to message #1808552] |
Thu, 27 June 2019 02:19  |
Ed Merks Messages: 31709 Registered: July 2009 |
I'm not sure why you'd need to do all these things, i.e., hand over specific classes? What information does the GenModel contain that you'd actually need? Normally I'd expect you'd just need to "hand over" the EPackage instance. After all, the whole framework is base on high-level reflection support such that all the downstream frameworks work properly even for dynamic models for which there is no GenModel and for which no specialized classes are generated.
Of course can can load a *.genmodel in exactly the same way you load any other resource with EMF, i.e., resourceSet.getResource(genModelURI, true), and then the root object in resource.getContents() will be a org.eclipse.emf.codegen.ecore.genmodel.GenModel. It's generally important when loading GenModels to initialize the resource set like this:resourceSet.getURIConverter().getURIMap().putAll(EcorePlugin.computePlatformURIMap(true));
The method org.eclipse.emf.ecore.plugin.EcorePlugin.getEPackageNsURIToGenModelLocationMap(boolean) is useful for finding an EPackage's corresponding GenModel (if it has one).
Ed Merks
FUDForum. Page generated in 0.02218 seconds
