Home » Eclipse Projects » Lyo » Polarion oslc consumer oauth
Polarion oslc consumer oauth [message #1808310] Fri, 21 June 2019 10:24 Go to next message
Michael C is currently offline Michael CFriend
Member
Hello, I' am not able to connect to Polarion ALM whith Lyo client.
Here is the code I used :
			String webContextUrl = "http://server/polarion/oslc";
			JazzRootServicesHelper helper = new JazzRootServicesHelper(webContextUrl, OSLCConstants.OSLC_RM_V2);
			OslcOAuthClient client = helper.initOAuthClient("OAuth Consumer Key", "aa");
			String res = client.lookupServiceProviderUrl(helper.getCatalogUrl(), "nameOfProject");
I got the consumer key by sending a post to :
http://serveur/polarion/oslc/services/oauth/requestKey.
The lyo api is always telling : Enter this URL in a browser and run again:
http://server/polarion/oslc/services/oauth/authorize?oauth_token=thegeneratedauthtoken.
So I'll go accept the key with a browser.
But when I run again it generates a different OAuth Consumer Key & authToken.
Also what about /polarion/oslc/services/oauth/approveKey
It seems the api can generate an oauthToken even if I did not approve the generate Key.
I guess I'm missing one step but I can't figure out what.
I tried to always use the same OAuth Consumer Key (one generated from the linked friends administration panel) but I got the same results.
[Updated on: Fri, 21 June 2019 10:43]
Report message to a moderator
Re: Polarion oslc consumer oauth [message #1808341 is a reply to message #1808310] Fri, 21 June 2019 16:55 Go to previous messageGo to next message
Andrii BerezovskyiFriend
Hello Michael,
Are you sure that the subsequent request is processed by the exact same OslcOAuthClient instance? It keeps state and if you re-initialise it, the auth won't work: https://github.com/eclipse/lyo.client/blob/2.4.0/oslc-java-client/src/main/java/org/eclipse/lyo/client/oslc/OslcOAuthClient.java#L187
Also, what versions of Lyo libraries are used?
Andrew
Eclipse Lyo project lead & OSLC Core TC voting member
Re: Polarion oslc consumer oauth [message #1808413 is a reply to message #1808341] Mon, 24 June 2019 08:44 Go to previous messageGo to next message
Member
I'm using Lyo 4.0.0. I also tried with 2.4.0. What version should I use ?
I noticed that I need to post to j_security_check so I tried to adapt the example. Here is the last code I used.
public class Main {
	private static final Logger logger = Logger.getLogger(Main.class.getName());
	public static void main(String[] args) throws RootServicesException, IOException, OAuthException, URISyntaxException, ResourceNotFoundException, InterruptedException, InvalidCredentialsException  {
		String webContextUrl = "http://serveur/polarion/oslc";
		String securityUrl = "http://serveur/polarion/j_security_check";
		String user = "admin";
		String password = "psw";
		String projectArea = "playground";
		HttpClient client = HttpClient.newHttpClient();
		HttpRequest request = HttpRequest.newBuilder()
			      .uri(URI.create(helper.getRequestConsumerKeyUrl()))
			      .timeout(Duration.ofMinutes(1))
			      .header("Content-Type", "application/json")
			      .POST(BodyPublishers.ofFile(Paths.get("D:\\Softwares\\eclipse 2019-03\\workspaceLyoClient\\lyo.client\\oslc-java-client\\src\\main\\java\\org\\eclipse\\lyo\\client\\test\\id.json")))
			      .build();
		HttpResponse<String> responseKey = client.send(request, BodyHandlers.ofString());
		if(responseKey.statusCode() == 200) {
			JsonParser parser = new JsonParser();
			JsonObject obj = parser.parse(responseKey.body()).getAsJsonObject();
			String key = obj.get("key").getAsString();
			System.out.println(key);
			OslcOAuthClient clientOslc = helper.initOAuthClient(key, "somesecret");
			try {
				String res = clientOslc.lookupServiceProviderUrl(helper.getCatalogUrl(), projectArea);
			catch (OAuthRedirectException oauthE) {
				HttpPost formPost = new HttpPost(securityUrl);
				List<NameValuePair> nvps = new ArrayList<NameValuePair>();
				nvps.add(new BasicNameValuePair("j_username", user));
				nvps.add(new BasicNameValuePair("j_password", password));
				formPost.setEntity(new UrlEncodedFormEntity(nvps, HTTP.UTF_8));
				org.apache.http.HttpResponse formResponse = clientOslc.getHttpClient().execute(formPost);
				Header location = formResponse.getFirstHeader("Location");
				System.out.println("Status : " + formResponse.getStatusLine().getStatusCode());//print 302
				System.out.println("location : " + location);	//print http://serveur/polarion
				HttpEntity entity = formResponse.getEntity();
				String responseString = EntityUtils.toString(entity, "UTF-8");
				System.out.println("Body : " + responseString);	//print blank
				EntityUtils.consume(formResponse.getEntity());
				//Third GET
				HttpGet request4 = new HttpGet(location.getValue());
				HttpClientParams.setRedirecting(request4.getParams(), false);
				org.apache.http.HttpResponse responseThird = clientOslc.getHttpClient().execute(request4);
				System.out.println("Status : " + responseThird.getStatusLine().getStatusCode()); //print 302
			    entity = responseThird.getEntity();
				EntityUtils.consume(responseThird.getEntity());
				//Since location is http://serveur/polarion this does not work
			/*	Map<String,String> oAuthMap = getQueryMap(location.getValue());
				System.out.println(oAuthMap.toString());
				String oauthToken = oAuthMap.get("oauth_token");
				String oauthverifier = oAuthMap.get("oauth_verifier");*/
				// The server requires an authentication: Create the login form
				HttpPost formPost2 = new HttpPost(oauthE.getRedirectURL() + "?oauth_token=" + oauthE.getAccessor().requestToken);
				formPost2.getParams().setParameter("oauth_token", oauthE.getAccessor().requestToken);
				formPost2.getParams().setParameter("oauth_verifier", "");
				formPost2.getParams().setParameter("authorize", "true");
				formPost2.addHeader("Content-Type","application/x-www-form-urlencoded;charset=UTF-8");
				formResponse = clientOslc.getHttpClient().execute(formPost2);
				System.out.println("Body : " + formResponse);
				Header header = formResponse.getFirstHeader("Content-Length");
				if ((header!=null) && (!("0".equals(header.getValue())))) {
					// The login failed
					throw new InvalidCredentialsException("Authentication failed");
				} else {
					// The login succeed
					// Step (3): Request again the protected resource
					System.out.println(res);
The login failed. Also if I put the 2st clientOslc.lookupServiceProviderUrl outside the if, it will still generate another token.
edit: I can log in to this URL with Postman.
[Updated on: Mon, 24 June 2019 09:06]
Re: Polarion oslc consumer oauth [message #1808462 is a reply to message #1808413] Tue, 25 June 2019 06:49 Go to previous message
Member
I recreated the topic here https://forum.open-services.net/t/polarion-oslc-consumer-implementation/269
Previous Topic:What I'd like to have in Lyo
Next Topic:How to get\to set a workflow state value using OSLC Java API in DNG
Current Time: Fri Feb 21 16:58:47 GMT 2020
Powered by FUDForum. Page generated in 0.03127 seconds
