Re: Papyrus preference keys [message #1808437 is a reply to message #1808064] |
Mon, 24 June 2019 15:33   |
Hi Oliver,
I will assume that you knew you could set those from the preferences inside the Papyrus RCP so I'll just tell you what the ones you are mentioning are supposed to do:
org.eclipse.papyrus.infra.gmfdiag.preferences/Global.enableAnimatedLayout=false
- This is used for the animation when executing one of the arrange actions on your diagram. It shouldn't have an impact on anything else.
org.eclipse.papyrus.infra.gmfdiag.preferences/Global.enableAnimatedZoom=false
- This setup is to enable, as the text suggests, the animation (a progressive increment instead of the direct result) when zooming into a diagram.
org.eclipse.papyrus.infra.gmfdiag.preferences/Global.showConnectionHandles=false
- I am not familiar with this one so I am afraid I can't really get you a specific answer.
org.eclipse.papyrus.infra.gmfdiag.preferences/PAPYRUS_NAVIGATION_DECORATOR_VISIBILITY=DISABLED
- This one is unfamiliar to me as well. I'll ask the rest of the team.
org.eclipse.papyrus.infra.gmfdiag.preferences/PAPYRUS_NAVIGATION_DOUBLECLICK_KIND=NO_NAVIGATION
- Papyrus allows you to set your own 'hyperlink' to another model/submodel/element. If this is set to false you won't get the popup dialog to control this.
(You can get this through Papyrus> Navigation)
Fwiw, those really should be modified inside the RCP itself or you might get a lot of them having seemingly no effect until you try the right action.
HTH, Cheers,
Quentin
FUDForum. Page generated in 0.02214 seconds
