Re: MARTE [message #1808118 is a reply to message #1808061] |
Mon, 17 June 2019 15:42 |
the current release of MARTE is a bit outdated, minor corrections are in the nightly build.
If you use MARTE with newer Eclipse versions (from oxygen onwards), the palette will no longer work as it uses a deprecated XML based customization mechanisms. However, the static profile itself and the property view works, i.e. you can apply the MARTE stereotypes via the "Profile" tab within the property view.
If you want to understand "all", you should have a look at the git sources: https://git.eclipse.org/c/papyrus/org.eclipse.papyrus-marte.git/.
HTH
Ansgar
Re: MARTE [message #1850160 is a reply to message #1850114] |
Fri, 18 February 2022 12:00 |
Yes, the MARTE component is old, but we currently do not have a newer one. It is still usable as profile (without palette) in the current version of Papyrus.
We plan to update to MARTE 1.2 (the specification version, not the version of the plugin) in the near future.
Re: MARTE [message #1857432 is a reply to message #1850160] |
Tue, 07 February 2023 14:12 |
Luca Cristoforetti Messages: 12 Registered: April 2018 |
I'm looking for an update site containing MARTE to use as target platform. So far I've been using the nightly build (https://ci.eclipse.org/papyrus/job/papyrus-marte-2022-03/lastSuccessfulBuild/artifact/releng/org.eclipse.papyrus.marte.p2/target/repository/) but recently my build fails:
[INFO] Fetching org.eclipse.papyrus.marte.static.profile_1.2.3.202204141415.jar from https://ci.eclipse.org/papyrus/job/papyrus-marte-2022-03/lastSuccessfulBuild/artifact/releng/org.eclipse.papyrus.marte.p2/target/repository/plugins/ (1.65MB)
[ERROR] An error occurred while transferring artifact canonical: osgi.bundle,org.eclipse.papyrus.marte.static.profile,1.2.3.202204141415 from repository https://ci.eclipse.org/papyrus/job/papyrus-marte-2022-03/lastSuccessfulBuild/artifact/releng/org.eclipse.papyrus.marte.p2/target/repository:
[ERROR] Problems downloading artifact: osgi.bundle,org.eclipse.papyrus.marte.static.profile,1.2.3.202204141415.:
[ERROR] Error reading signed content:/tmp/signatureFile4946556712229575211.jar
[ERROR] Internal error: org.eclipse.tycho.repository.local.MirroringArtifactProvider$MirroringFailedException: Could not mirror artifact osgi.bundle,org.eclipse.papyrus.marte.static.profile,1.2.3.202204141415 into the local Maven repository.See log output for details. An error occurred while processing the signatures for the file: /tmp/signatureFile4946556712229575211.jar: No algorithm found for 1.2.840.113549.1.1.12 -> [Help 1]
org.apache.maven.InternalErrorException: Internal error: org.eclipse.tycho.repository.local.MirroringArtifactProvider$MirroringFailedException: Could not mirror artifact osgi.bundle,org.eclipse.papyrus.marte.static.profile,1.2.3.202204141415 into the local Maven repository.See log output for details.
I understand that the problem is about a different RSA signature and it could be solved updating Tycho (currently 1.7.0) to version 2.4.0, but I tried and this involves a waterfall of changes.
I would like to keep the MARTE plugins as they were before mid January.
Is there an update site containing them?
Luca
Re: MARTE [message #1857483 is a reply to message #1857476] |
Thu, 09 February 2023 18:41 |
Hi Luca,
Looking at the repo it seems weird that, if you have this kind of tycho incompatibility, it even would not have worked mid january as the latest commit is from 9 months ago.
Did you change anything since then on your end ? can you provide the repo or more informations/a fuller log so as to understand why you encounter this ?
/Quentin
[Updated on: Thu, 09 February 2023 18:41] Report message to a moderator
FUDForum. Page generated in 0.04645 seconds
