Home » Newcomers » Newcomers » Eclipse RCP 4.11 and Open JDK 11(Compatibility of Eclipse RCP 4.11 and JDK 11)
Eclipse RCP 4.11 and Open JDK 11 [message #1808041] Fri, 14 June 2019 12:03 Go to next message
Neju Nelson is currently offline Neju NelsonFriend
Is it possible to create a RCP Application in Eclipse 4.11 with Open JDK 11
Re: Eclipse RCP 4.11 and Open JDK 11 [message #1808046 is a reply to message #1808041] Fri, 14 June 2019 14:04 Go to previous messageGo to next message
I believe so, but Eclipse is generally not well-tested with Open JDK. Why not use Eclipse 4.12?
Re: Eclipse RCP 4.11 and Open JDK 11 [message #1808047 is a reply to message #1808046] Fri, 14 June 2019 14:17 Go to previous messageGo to next message
Thanks for the quick reply Ed,
I am using the Release package Eclipse IDE 2019-03 R Packages which is latest one in https://www.eclipse.org/downloads/packages/
Should I try with the latest stable 4.12 in the download page https://download.eclipse.org/eclipse/downloads/
Is the 4.12 tested with Open JDK as well
Re: Eclipse RCP 4.11 and Open JDK 11 [message #1808053 is a reply to message #1808047] Sat, 15 June 2019 05:25 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin DahyabhaiFriend
It should be: https://www.eclipse.org/projects/project-plan.php?planurl=http://www.eclipse.org/eclipse/development/plans/eclipse_project_plan_4_12.xml#target_environments
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: Eclipse RCP 4.11 and Open JDK 11 [message #1808055 is a reply to message #1808053] Sat, 15 June 2019 06:54 Go to previous messageGo to next message
Good link Nitin. Neju, sorry I forgot that 4.12 is the current release, which is actually wrapped up now but won't be available until next week Wednesday.
Re: Eclipse RCP 4.11 and Open JDK 11 [message #1808898 is a reply to message #1808055] Thu, 04 July 2019 09:07 Go to previous messageGo to next message
Thanks for the Reply.
Did eclipse stopped releasing 32 bit version. As I can see 32 bit option until 4.9 and not from 4.10 onward.
Re: Eclipse RCP 4.11 and Open JDK 11 [message #1808907 is a reply to message #1808898] Thu, 04 July 2019 10:16 Go to previous messageGo to next message
Yes, there is no longer support for 32 bit versions for any of the supported platforms.
Re: Eclipse RCP 4.11 and Open JDK 11 [message #1816508 is a reply to message #1808907] Wed, 30 October 2019 10:03 Go to previous messageGo to next message
Will it induce any issues in the migration like technical , re usability, functionality etc. if we change the application to Event Driven pattern as Observer pattern is marked as deprecated from JDK 11 onwards
Neju
Re: Eclipse RCP 4.11 and Open JDK 11 [message #1816514 is a reply to message #1816508] Wed, 30 October 2019 11:15 Go to previous message
I don't know what you're specifically referring to with Event Driven versus Observer with respect to the JDK itself. The platform frameworks have not changed such patterns.
Previous Topic:Problem in connecting with Java
Next Topic:convert parameter
Current Time: Fri May 29 21:17:03 GMT 2020
Powered by FUDForum. Page generated in 0.03428 seconds
