Home » Eclipse Projects » 4DIAC - Framework for Distributed Industrial Automation and Control » Group box "Create Connection" missing in 4diac 1.10(View "Create connection" to connect FBs which are distant from each other)
Group box "Create Connection" missing in 4diac 1.10 [message #1807649] Wed, 05 June 2019 15:17 Go to next message
Felipe Adriano is currently offline Felipe AdrianoFriend
Member
Unfortunately 4DIAC-IDE cant scroll screen when trying to move a draggable object outside the current view. This make the connection of distant FBs inputs/events a little bit harder.
But 4DIAC 1.9 had a view called Create connection that made it easier (attached image). The problem is that this option is not available more in 4DIAC 1.10.
index.php/fa/35699/0/
How can I bring back this view to new version of 4diac?
Is possible to add a search mechanism to help find the Target FB combobox?
[Updated on: Wed, 05 June 2019 15:23]
Report message to a moderator
Re: Group box "Create Connection" missing in 4diac 1.10 [message #1807650 is a reply to message #1807649] Wed, 05 June 2019 15:53 Go to previous messageGo to next message
Alois Zoitl is currently offline Alois ZoitlFriend
As you point it out in your last question the usability of this feature was not very good. We reevaluated how this feature could be improved. Therefore we removed that part of the property sheet and replaced it with a new version. When you select two interface elements in your application you will get a new property sheet which allows you to create a connection between the two selected entities. We hope that this new way is better compared to the old version.
Alois
Re: Group box "Create Connection" missing in 4diac 1.10 [message #1807652 is a reply to message #1807650] Wed, 05 June 2019 16:00 Go to previous messageGo to next message
Member
Wow..
I didn't know the option of select two interface elements. Really the usability is so much better, the complexity of search mechanism is unnecessary.
Tanks by the help.
Re: Group box "Create Connection" missing in 4diac 1.10 [message #1807653 is a reply to message #1807652] Wed, 05 June 2019 16:23 Go to previous message
Thanks for the feedback. This is very valuable for us.
Previous Topic:Time to real conversion in FORTE 10
Next Topic:dll import in programming
Current Time: Mon Jun 14 01:02:14 GMT 2021
Powered by FUDForum. Page generated in 0.01421 seconds
