Home » Eclipse Projects » Kura » [kura 4.1.0]Problems with CloudSubscriber(onMessageArrived method not works)
[kura 4.1.0]Problems with CloudSubscriber [message #1807606] Tue, 04 June 2019 14:36 Go to next message
giuseppe ferro is currently offline giuseppe ferroFriend
Member
Hi all,
I need help.
I'm testing Demo Heater kura bundle.
in particular I want to add.implement and test the CloudSubscriber.
see attached code:
public class Heater implements ConfigurableComponent, CloudSubscriberListener, CloudConnectionListener, CloudDeliveryListener {
private CloudSubscriber cloudSubscriber;
public void setCloudSubscriber(CloudSubscriber cloudSubscriber) {
this.cloudSubscriber = cloudSubscriber;
this.cloudSubscriber.registerCloudSubscriberListener(Heater.this);
this.cloudSubscriber.registerCloudConnectionListener(Heater.this);
public void unsetCloudSubscriber(CloudSubscriber cloudSubscriber) {
this.cloudSubscriber.unregisterCloudSubscriberListener(Heater.this);
this.cloudSubscriber.unregisterCloudConnectionListener(Heater.this);
this.cloudSubscriber = null;
public void onMessageArrived(KuraMessage message) {
logReceivedMessage(message);
logger.debug("//////////////// OnReceivedMessage ///////////////////");
I have create on kura 4.1.0 one publisher and one subscriber. The topic is the same so i can publish into a topic and "listen" from the same topic.
but i can't read or receive correctly the message published.
I attached the following kura.log:
2019-06-04T14:20:33,249 [] INFO o.e.k.c.d.DataServiceImpl - Storing message on topic: #account-name/#client-id/realtime/command, priority: 7
2019-06-04T14:20:33,256 [] DEBUG o.e.k.c.d.s.DbDataStore - Store message count: 93
2019-06-04T14:20:33,264 [] INFO o.e.k.c.d.DataServiceImpl - Stored message on topic: #account-name/#client-id/realtime/command, priority: 7
2019-06-04T14:20:33,269 [DataServiceImpl:Submit] DEBUG o.e.k.c.d.DataServiceImpl - Publishing message with ID: 81398 on topic: #account-name/#client-id/realtime/command, priority: 7
2019-06-04T14:20:33,272 [] INFO o.e.k.d.h.Heater - Published message: org.eclipse.kura.message.KuraPayload@15295e3
2019-06-04T14:20:33,287 [DataServiceImpl:Submit] DEBUG o.e.k.c.d.t.m.MqttDataTransport - Replaced tokens in topic #account-name/#client-id/realtime/command with: /GK400001116GH1/realtime/command
2019-06-04T14:20:33,291 [DataServiceImpl:Submit] INFO o.e.k.c.d.t.m.MqttDataTransport - Publishing message on topic: /GK400001116GH1/realtime/command with QoS: 1
2019-06-04T14:20:33,299 [MQTT Call: GK400001116GH1] DEBUG o.e.k.c.d.t.m.MqttDataTransport - Delivery complete for message with ID: 15863
2019-06-04T14:20:33,302 [MQTT Call: GK400001116GH1] DEBUG o.e.k.c.d.t.m.DataTransportListenerS - No registered listener services. Ignoring onMessageConfirmed
2019-06-04T14:20:33,310 [DataServiceImpl:Submit] DEBUG o.e.k.c.d.t.m.MqttDataTransport - Published message with ID: 15863
2019-06-04T14:20:33,317 [DataServiceImpl:Submit] DEBUG o.e.k.c.d.DataServiceImpl - Published message with ID: 81398 and MQTT message ID: 15863
2019-06-04T14:20:33,319 [MQTT Call: GK400001116GH1] DEBUG o.e.k.c.d.DataServiceImpl - Confirmed message with MQTT message ID: 15863 on session ID: GK400001116GH1-tcp://xxx.xxx.xxx.xxx:1886
2019-06-04T14:20:33,321 [MQTT Call: GK400001116GH1] INFO o.e.k.c.d.DataServiceImpl - Confirmed message ID: 81398 to store
2019-06-04T14:20:33,326 [DataServiceImpl:Submit] DEBUG o.e.k.c.d.DataServiceListenerS - No registered listener services. Ignoring onMessagePublished
2019-06-04T14:20:33,335 [DataServiceImpl:Submit] DEBUG o.e.k.c.d.DataServiceImpl - Suspending publishing thread indefinitely
2019-06-04T14:20:33,339 [MQTT Call: GK400001116GH1] DEBUG o.e.k.c.d.DataServiceListenerS - No registered listener services. Ignoring onMessageConfirmed
2019-06-04T14:20:33,342 [pool-79-thread-4] INFO o.e.k.d.h.Heater - Confirmed message with id: 81398
2019-06-04T14:20:33,346 [DataServiceImpl:Submit] DEBUG o.e.k.c.d.DataServiceImpl - Suspending publishing thread indefinitely
2019-06-04T14:20:33,348 [MQTT Call: GK400001116GH1] DEBUG o.e.k.c.d.t.m.MqttDataTransport - Message arrived on topic: /GK400001116GH1/realtime/command
2019-06-04T14:20:33,350 [MQTT Call: GK400001116GH1] DEBUG o.e.k.c.d.t.m.DataTransportListenerS - No registered listener services. Ignoring onMessageArrived
2019-06-04T14:20:33,352 [MQTT Call: GK400001116GH1] DEBUG o.e.k.c.d.DataServiceImpl - Message arrived on topic: /GK400001116GH1/realtime/command
2019-06-04T14:20:33,354 [MQTT Call: GK400001116GH1] DEBUG o.e.k.c.d.DataServiceListenerS - No registered listener services. Ignoring onMessageArrived
2019-06-04T14:20:33,356 [MQTT Call: GK400001116GH1] INFO o.e.k.c.c.CloudServiceImpl - Message arrived on topic: /GK400001116GH1/realtime/command
2019-06-04T14:20:33,361 [DataServiceImpl:Submit] DEBUG o.e.k.c.d.DataServiceImpl - Suspending publishing thread indefinitely
I'm expecting the Logger String on the following Callback
I have attached two pictures of Kura WEB UI configuration
Can someone help me?
thanks a lot
Bye
Giuseppe
Re: [kura 4.1.0]Problems with CloudSubscriber [message #1807616 is a reply to message #1807606] Wed, 05 June 2019 07:05 Go to previous messageGo to next message
Matteo Maiero is currently offline Matteo MaieroFriend
Maybe try to replicate what done for the example publisher: https://github.com/eclipse/kura/tree/develop/kura/examples/org.eclipse.kura.example.publisher
Matteo
Re: [kura 4.1.0]Problems with CloudSubscriber [message #1807617 is a reply to message #1807616] Wed, 05 June 2019 07:23 Go to previous messageGo to next message
Member
Hi Matteo,
thanks for your reply.
To add the Subscriber, I have modified Demo Heater using example publisher..
by the way, I have install example publisher from kura eclipse Marketplace but seems don't work
tail -f /var/log/kura.log
2019-06-05T07:14:22,973 [qtp9715618-72] INFO o.e.k.c.c.ConfigurationServiceImpl - Registering metatype pid: org.eclipse.kura.example.publisher.ExamplePublisher ...
It's the only output in kura
i have the same output if I import project from github ,create dp package and install into bbb
what am I doing wrong?
Giuseppe
Re: [kura 4.1.0]Problems with CloudSubscriber [message #1807618 is a reply to message #1807617] Wed, 05 June 2019 07:25 Go to previous messageGo to next message
Compared to the heater that is a singleton component that has a single instance that automatically starts, the example publisher is a factory. To instantiate it, you need to use the + button on the left, select the example publisher factory and provide a name. It will create a new instance that will be listed in the services section of the web UI.
Matteo
Re: [kura 4.1.0]Problems with CloudSubscriber [message #1807622 is a reply to message #1807618] Wed, 05 June 2019 10:09 Go to previous messageGo to next message
Member
You are right but nothing is changed.
see files attached.
the method
private void logReceivedMessage(KuraMessage msg)
never shows up when message arrives on topic.
Thanks a lot for your attention and quick answer
Re: [kura 4.1.0]Problems with CloudSubscriber [message #1807623 is a reply to message #1807622] Wed, 05 June 2019 10:13 Go to previous messageGo to next message
Is the cloud connection subscriber properly configured?
Matteo
Re: [kura 4.1.0]Problems with CloudSubscriber [message #1807624 is a reply to message #1807623] Wed, 05 June 2019 10:32 Go to previous messageGo to next message
Member
Yes.
I follow this guide
https://eclipse.github.io/kura/cloud-api/3-app-dev-guide.html
--"The CloudSubscriber will invoke the onMessageArrived() method when new messages are received"-- this method (callback) is never invoked
-- "The CloudSubscriber will invoke the onMessageConfirmed() method when a published message is confirmed."-- OK
from the files attached previously you can see all the parameters of CloudSubscriber an Publisher.
Moreover I use the default example publisher from market place.
the kura log seems to be Ok. i have no exception or error.
Is it possible that i need a Kura bundle for Subscribe and an other Kura bundle for Publish?
Re: [kura 4.1.0]Problems with CloudSubscriber [message #1807633 is a reply to message #1807624] Wed, 05 June 2019 11:36 Go to previous messageGo to next message
What is the configuration of the "heaterSubscriber" component?
Re: [kura 4.1.0]Problems with CloudSubscriber [message #1807634 is a reply to message #1807633] Wed, 05 June 2019 11:48 Go to previous messageGo to next message
Member
Application Id: realtime/command
Application Topic: (empty)
Qos: 1
Kind of Message: Data
Re: [kura 4.1.0]Problems with CloudSubscriber [message #1807886 is a reply to message #1807634] Tue, 11 June 2019 14:17 Go to previous message
Member
Hi Matteo,
I was able to setup correctly the CloudSuscriber.
It is mandatory to fill Topic Context Account-Name in MqttDataTransport
Thanks for your time
Previous Topic:Send data from raspberry and read them from PC
Next Topic:KuraPayload body
Current Time: Wed Jul 28 04:40:49 GMT 2021
Powered by FUDForum. Page generated in 0.02755 seconds
