Home » Eclipse Projects » Sirius » Drag and Drop.
Drag and Drop. [message #1807604] Tue, 04 June 2019 14:14 Go to next message
Bushra Harraq is currently offline Bushra HarraqFriend
I have the following Metamodel:
http://prntscr.com/nxhufm
I want now the following Scenario.
I want to drag a process Segment B, which is a container, in the process Segment A.
The logic would be, that A is now a children of B.
http://prntscr.com/nxia67
Thanks in advance,
Bushra
[Updated on: Tue, 04 June 2019 14:14]
Report message to a moderator
Re: Drag and Drop. [message #1808332 is a reply to message #1807604] Fri, 21 June 2019 15:29 Go to previous message
Pierre Guilet is currently offline Pierre GuiletFriend
You should define a container drop tool https://www.eclipse.org/sirius/doc/specifier/diagrams/Diagrams.html#container_tools.
Then in the operation make B a child of A. See https://www.eclipse.org/sirius/doc/specifier/general/Model_Operations.html to understand how it works.
Use a change context with
var:newSemanticContainer
that will be A.
Then a Set operation to make B a child of A with something like
aql:newSemanticContainer .children->insertAt(0,element)
as value expression and children as feature.
Pierre Guilet - Obeo
Previous Topic:ELK nodes
Next Topic:How to add listener to button in property view
Current Time: Sat Apr 04 03:16:23 GMT 2020
Powered by FUDForum. Page generated in 0.03121 seconds
