Home » Modeling » TMF (Xtext) » Deploying an local Xtext Plugin
Deploying an local Xtext Plugin [message #1807497] Fri, 31 May 2019 09:09 Go to next message
TheEMF User is currently offline TheEMF UserFriend
Member
I made a DSL with Xtext.
I generated the plugin using this procedure https://wiki.eclipse.org/FAQ_How_do_I_create_an_update_site_(site.xml)%3F
I added the necessary plugins (dsl, dsl.ide and dsl.ui).
But everything seems okay and I can see it among "insttaled software" but Eclipse does not seem to recognize the syntax of my DSL ?
PS: My dsl works without any problem when I run it as a configuration with a new Eclipse instance but not when installed as a plugin.
[Updated on: Fri, 31 May 2019 09:10]
Report message to a moderator
Re: Deploying an local Xtext Plugin [message #1807498 is a reply to message #1807497] Fri, 31 May 2019 09:14 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
The wizard has an option to for an update size too.
Please use the host osgi console to find out what the problem is
Hit the plus button in the console view and select host osgi console
Type
ss yourdsl
This will show your plugins if the were installed correctly
If they are not active type
start <ID>
To start them or to find out what the problem is
Use the ids the ss command gave you
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/xtext/
Twitter : @chrdietrich
Re: Deploying an local Xtext Plugin [message #1807499 is a reply to message #1807498] Fri, 31 May 2019 09:15 Go to previous messageGo to next message
Also have a look at error log view for errors
Re: Deploying an local Xtext Plugin [message #1807501 is a reply to message #1807499] Fri, 31 May 2019 10:34 Go to previous messageGo to next message
Member
Thanks for your response.
Well it was on STARTING then I did start <ID> et it become ACTIVE but I still can't launch an editor of my DSL and syntax is not recognized.
There are no errors
[Updated on: Fri, 31 May 2019 10:35]
Re: Deploying an local Xtext Plugin [message #1807502 is a reply to message #1807501] Fri, 31 May 2019 10:36 Go to previous messageGo to next message
are you sure the file extension is correct.
what does the open with menu show?
is there are section for yourdsl in the preferences?
with no input from your side its impossible to help
Re: Deploying an local Xtext Plugin [message #1807504 is a reply to message #1807502] Fri, 31 May 2019 11:06 Go to previous messageGo to next message
Member
I reproduced the problem here : https://github.com/aduninon/GeetingDSL
Can you please check it out
When I install the plugin in 'update' it is not recognized.
And I use the feature in 'feature' folder
[Updated on: Fri, 31 May 2019 11:07]
Re: Deploying an local Xtext Plugin [message #1807506 is a reply to message #1807504] Fri, 31 May 2019 11:11 Go to previous message
I done understand
Is install the problem or using after install
Previous Topic:[LS] Access to server configuration values
Next Topic:how to check the condition for instance of class had been created in xtext editor
Current Time: Fri Feb 21 01:40:39 GMT 2020
Powered by FUDForum. Page generated in 0.05817 seconds
