Home » Modeling » TMF (Xtext) » how to check the condition for instance of class had been created in xtext editor
how to check the condition for instance of class had been created in xtext editor [message #1807441] Thu, 30 May 2019 08:43 Go to next message
Nagashree KN is currently offline Nagashree KNFriend
I have created xtext projects using existing ecore model. There i have one condition like instance of class should be only one.
In Xtext editor on doing contrl+space it will list down the class names to be created. In my editor i want to create class instance only once, means again on doing control+space it should not show the created class name in the list only.
i am attaching images for better understanding.
Any one can please help me how i can do this kind of validations in editor.
Thanks!
Re: how to check the condition for instance of class had been created in xtext editor [message #1807442 is a reply to message #1807441] Thu, 30 May 2019 08:45 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
simply filter the proposals.
have a look what xtext generates in the abstractyourdslproposal provider and customize it to your needs
alternatively you could do the filtering inside the scopeprovider too. (might need use of nodemodelutils)
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/xtext/
Twitter : @chrdietrich
[Updated on: Thu, 30 May 2019 09:03]
Report message to a moderator
Re: how to check the condition for instance of class had been created in xtext editor [message #1807503 is a reply to message #1807442] Fri, 31 May 2019 11:04 Go to previous messageGo to next message
Thanks for quick replay. i had a look at proposalprovider class.
i am not able achieve one thing here that is, first time on doing ctrl+space in editor it will show the list . from that list i will select one thing. now what i want is again on doing ctrl+space the one which i have created it should not shown in the list . i tried by overriding the method complete[elementname]_[Featurename]() but still it is not working.
How i can achieve this?
Re: how to check the condition for instance of class had been created in xtext editor [message #1807505 is a reply to message #1807503] Fri, 31 May 2019 11:08 Go to previous messageGo to next message
There is a complete xxxx method for your reference
Override it. Have a look at what the super impl does
It calls lookupCrossReference
There are variants that have a filter
Call it with a filter you implement yourself
Instead of the always true filter
The method also has a filter method that gives you access to the current model
Re: how to check the condition for instance of class had been created in xtext editor [message #1807507 is a reply to message #1807505] Fri, 31 May 2019 11:12 Go to previous message
See also https://www.eclipse.org/forums/index.php?t=msg&th=488755&goto=1063652&#msg_1063652
Previous Topic:Deploying an local Xtext Plugin
Next Topic:Code Mining with Embedded Editor
Current Time: Sun Jan 19 04:12:38 GMT 2020
Powered by FUDForum. Page generated in 0.02154 seconds
