Home » Newcomers » Newcomers » Where to download "com.amazonaws.eclipse:org.eclipse.jst.web_sdk.feature.feature.group"(I need to know where I can download a missing jar file)
Where to download "com.amazonaws.eclipse:org.eclipse.jst.web_sdk.feature.feature.group" [message #1807378] Tue, 28 May 2019 20:14 Go to next message
Daniel Brower is currently offline Daniel BrowerFriend
I was following the instructions at https://github.com/aws/aws-toolkit-eclipse under the heading "Import into Eclipse and Set up Development Environment", where it says "2. Run the setup.sh script if you havn't created the target platform: sh setup.sh." when I ran into errors with these messages:
[ERROR] Cannot resolve project dependencies:
[ERROR] Software being installed: com.amazonaws.eclipse.devide raw:1.0.0.'SNAPSHOT'/format(n[.n=0;[.n=0;[-S]]]):1.0.0-SNAPSHOT
[ERROR] Missing requirement: com.amazonaws.eclipse.devide raw:1.0.0.'SNAPSHOT'/format(n[.n=0;[.n=0;[-S]]]):1.0.0-SNAPSHOT requires 'org.eclipse.jst.web_sdk.feature.feature.group 0.0.0' but it could not be found
[ERROR]
[ERROR] See (webpage).
[ERROR] Cannot resolve dependencies of MavenProject: com.amazonaws.eclipse:com.amazonaws.eclipse.devide:1.0.0-SNAPSHOT @ /Users/shinehah/git/aws-toolkit-eclipse-java-ee-and-report/releng/com.amazonaws.eclipse.devide/pom.xml: See log for details -> [Help 1]
[ERROR]
[ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch.
[ERROR] Re-run Maven using the -X switch to enable full debug logging.
[ERROR]
[ERROR] For more information about the errors and possible solutions, please read the following articles:
[ERROR] [Help 1] (webpage)
It looks like I need to tell the pom file for "com.amazonaws.eclipse.devide" where to find the jar file for that module, which has the name "org.eclipse.jst.web_sdk.feature.feature.group".
I tried adding more content in the pom.xml file, but I still get errors saying that jar file is missing.
I attached the original pom.xml file and the one I added content to.
Where would I find that jar file? I did a search on Google but did not find it.
If that is not the problem, how would I fix this so that I can execute this step to run "sh setup.sh" successfully?
  • Attachment: pom.xml
    (Size: 0.68KB, Downloaded 117 times)
  • Attachment: altered_pom.xml
    (Size: 0.93KB, Downloaded 104 times)
[Updated on: Tue, 28 May 2019 20:16] by Moderator
Report message to a moderator
Re: Where to download "com.amazonaws.eclipse:org.eclipse.jst.web_sdk.feature.feature.group" [message #1807380 is a reply to message #1807378] Wed, 29 May 2019 03:32 Go to previous messageGo to next message
It sounds like the same issue as posted in their issues tracker:
https://github.com/aws/aws-toolkit-eclipse/issues/145
Ed Merks
Re: Where to download "com.amazonaws.eclipse:org.eclipse.jst.web_sdk.feature.feature.group& [message #1807381 is a reply to message #1807380] Wed, 29 May 2019 03:40 Go to previous messageGo to next message
Yes. That's my post.
Re: Where to download "com.amazonaws.eclipse:org.eclipse.jst.web_sdk.feature.feature.group& [message #1807429 is a reply to message #1807381] Wed, 29 May 2019 20:30 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin DahyabhaiFriend
Don't you need to at least specify what the tycho.version property value is? Have you done as it suggested and rerun the mvn command with additional options?
_
Nitin Dahyabhai
Eclipse Web Tools Platform
[Updated on: Wed, 29 May 2019 20:30]
Re: Where to download "com.amazonaws.eclipse:org.eclipse.jst.web_sdk.feature.feature.group& [message #1807430 is a reply to message #1807429] Wed, 29 May 2019 20:40 Go to previous message
I didn't realize I needed to specify the tycho.version. I have rerun the mvn command, but not with additional options. What options should I use?
Previous Topic:Installing Eclipse IDE 2019‑03
Next Topic:org.eclipse.persistence.exceptions.ValidationException
Current Time: Tue Apr 16 06:36:15 GMT 2024
Powered by FUDForum. Page generated in 0.19658 seconds
