Home » Eclipse Projects » Plugin Development Environment (PDE) » Compiler compliance in build.properties limited to Java 8?
Compiler compliance in build.properties limited to Java 8? [message #1807372] Tue, 28 May 2019 17:46
Glenn Burkhardt is currently offline Glenn BurkhardtFriend
For a headless build, I've tried setting 'javacSource' and 'javacTarget' to 1.9 and 1.11, but these values apparently are not recognized properly, because the build fails with errors that indicate the Java compliance level is set to the the default 1.3, e.g.,
Syntax error, parameterized types are only available if source level is 1.5 or greater
Using the value 1.8 works. Am I wrong in thinking that this is a bug in Eclipse 4.11? Or do I have the naming convention wrong for the Java version. I'm trying to build with Java 11.
Previous Topic:Exporting product
Next Topic:NPE in ColumnViewerEditor due to cellEditor is null
Current Time: Sun Oct 02 19:57:06 GMT 2022
Powered by FUDForum. Page generated in 0.02229 seconds
