Home » Eclipse Projects » Jubula » Exception with running Jubula-core on Eclipse
Exception with running Jubula-core on Eclipse [message #1807146] Thu, 23 May 2019 14:48 Go to next message
Nizar Tenzekhti is currently offline Nizar TenzekhtiFriend
I try to running Jubula-core on eclipse to develop new test cases and toolkits, i built the project using build.xml, Building was successful, but not all dependencies was installed, i installed them manually. now Jubula project run correctly but when i choose one of the test panel : new test, open, select DataBase, import, export or Delete an exception occurred.
index.php/fa/35624/0/
The Exception:
!ENTRY org.eclipse.ui 4 0 2019-05-23 15:37:16.819
!MESSAGE Unhandled event loop exception
!STACK 0
java.lang.NoClassDefFoundError: org/apache/commons/collections/BidiMap
at org.eclipse.jubula.client.ui.handlers.project.AbstractSelectDatabaseHandler.executeImpl(AbstractSelectDatabaseHandler.java:82)
at org.eclipse.jubula.client.ui.handlers.AbstractHandler.execute(AbstractHandler.java:79)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:294)
at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:96)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:58)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:320)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:254)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:173)
at org.eclipse.e4.core.commands.internal.HandlerServiceHandler.execute(HandlerServiceHandler.java:156)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:497)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:490)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:213)
at org.eclipse.ui.internal.handlers.LegacyHandlerService.executeCommand(LegacyHandlerService.java:403)
at org.eclipse.ui.internal.handlers.LegacyHandlerService.executeCommand(LegacyHandlerService.java:379)
at org.eclipse.jubula.client.ui.utils.CommandHelper.executeCommand(CommandHelper.java:79)
at org.eclipse.jubula.client.ui.utils.CommandHelper.executeCommand(CommandHelper.java:57)
at org.eclipse.jubula.client.ui.handlers.project.AbstractProjectHandler.execute(AbstractProjectHandler.java:33)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.executeItem(HandledContributionItem.java:438)
at org.eclipse.e4.ui.workbench.renderers.swt.AbstractContributionItem.handleWidgetSelection(AbstractContributionItem.java:449)
at org.eclipse.e4.ui.workbench.renderers.swt.AbstractContributionItem.lambda$2(AbstractContributionItem.java:475)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:89)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4131)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1055)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3944)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3547)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1173)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:338)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1062)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:155)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:644)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:566)
at org.eclipse.jubula.app.Launcher.start(Launcher.java:212)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:137)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:107)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:400)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:661)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:597)
at org.eclipse.equinox.launcher.Main.run(Main.java:1476)
at org.eclipse.equinox.launcher.Main.main(Main.java:1449)
Caused by: java.lang.ClassNotFoundException: org.apache.commons.collections.BidiMap cannot be found by org.eclipse.jubula.client.core_7.0.2.qualifier
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:511)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:422)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:414)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:153)
... 65 more
Re: Exception with running Jubula-core on Eclipse [message #1807388 is a reply to message #1807146] Wed, 29 May 2019 07:02 Go to previous messageGo to next message
Marvin Mueller is currently offline Marvin MuellerFriend
It seems that the org.apache.commons.collections bundle is missing.
Can you please elaborate on how you build the eclipse and which build.xml you are referring to?
best regards
Marvin Mueller
Re: Exception with running Jubula-core on Eclipse [message #1807407 is a reply to message #1807388] Wed, 29 May 2019 09:30 Go to previous message
Hello Mr Marvin,
Thank you for your replay,
There are more than the org.apache.commons.collections bundles are missing, so i added them manually.
I used the Ant Build (Run as Ant Build) on the eclipse to build the Build.xml file.
index.php/fa/35654/0/
I cloned the project from GitHub: https://github.com/eclipse/jubula.core
You'll find the Build.xml file attached below.
Nizar
  • Attachment: AntBuild.bmp
    (Size: 1.85MB, Downloaded 107 times)
  • Attachment: build.xml
    (Size: 2.16KB, Downloaded 32 times)
[Updated on: Wed, 29 May 2019 09:32]
Report message to a moderator
Previous Topic:"Error occurred" closing a window
Next Topic:how to download older version
Current Time: Tue Jan 26 18:06:02 GMT 2021
Powered by FUDForum. Page generated in 0.02178 seconds
