Home » Modeling » TMF (Xtext) » How to import implicitly the namespace from importURI
How to import implicitly the namespace from importURI [message #1807083] Wed, 22 May 2019 10:59 Go to next message
Cyril Grey is currently offline Cyril GreyFriend
Hello everyone!
I have a Scoping issue and I hope you could help me ...
I'm trying to achieve the following:
1. Restrict the default GlobalScope only to explicitly imported resources (and some default imports)
2. Access it without use of fully qualified name
So, I can address to elements by their fully qualified name, but I would want to automatically import the namespace, to address to ID directly (like if it was under the same namespace).
How can I add all importURI resources to the current scope?
For example:
<ModelName>.<ElementName> to <ElementName>
in some cases: <ModelName>.<OuterElement>.<InnerElement> to just <InnerElement> ?
Because my actual grammar is too big and irrelevant for this question, let's say that I have the following (very simplified):
Grammar:
Model:
	name=ID ':'
	include+=Include*
	ownedNamedElements+=NamedElement*
	greeting+=Greeting*;
Include:
	'import' importURI=STRING
NamedElement:
	'def' name=ID
Greeting:
	'Hi' name=[NamedElement|QualifiedName] '!'
QualifiedName:
	ID ('.'ID)*
ResourceDescriptionStrategy:
class CGResourceDescriptionStrategy extends DefaultResourceDescriptionStrategy{
	public static final String INCLUDES = "includes"
	@Inject
	ImportUriResolver uriResolver
	override createEObjectDescriptions(EObject eObject, IAcceptor<IEObjectDescription> acceptor) {
		if(eObject instanceof Model) {
			this.createEObjectDescriptionForModel(eObject, acceptor)
			return true
		else {
			super.createEObjectDescriptions(eObject, acceptor)
	def void createEObjectDescriptionForModel(Model model, IAcceptor<IEObjectDescription> acceptor) {
		val uris = newArrayList()
		model.include.forEach[uris.add(uriResolver.apply(it))]
		val userData = new HashMap<String,String>
		userData.put(INCLUDES, uris.join(","))
		acceptor.accept(EObjectDescription.create(QualifiedName.create(model.eResource.URI.toString), model, userData))
RuntimeModule:
class CGRuntimeModule extends AbstractCGRuntimeModule {
	def Class<? extends IDefaultResourceDescriptionStrategy> bindIDefaultResourceDescriptionStrategy() {
	override Class<? extends IGlobalScopeProvider> bindIGlobalScopeProvider() {
		CGGlobalScopeProvider;
CGGlobalScopeProvider:
class CGGlobalScopeProvider extends ImportUriGlobalScopeProvider{
static final Splitter SPLITTER = Splitter.on(',');
	@Inject
	IResourceDescription.Manager descriptionManager;
	@Inject
	IResourceScopeCache cache;
	override protected getImportedUris(Resource resource) {
		return cache.get(CGGlobalScopeProvider.getSimpleName(), resource, new Provider<LinkedHashSet<URI>>() {
			override get() {
				val uniqueImportURIs = collectImportUris(resource, new LinkedHashSet<URI>())
				val uriIter = uniqueImportURIs.iterator()
				while(uriIter.hasNext()) {
					if (!EcoreUtil2.isValidUri(resource, uriIter.next()))
						uriIter.remove()
				return uniqueImportURIs
			def LinkedHashSet<URI> collectImportUris(Resource resource, LinkedHashSet<URI> uniqueImportURIs) {
				val resourceDescription = descriptionManager.getResourceDescription(resource)
				val models = resourceDescription.getExportedObjectsByType(ModelPackage.Literals.MODEL)
				models.forEach[
					val userData = getUserData(CGResourceDescriptionStrategy.INCLUDES)
					if(userData !== null) {
						SPLITTER.split(userData).forEach[uri |
							var includedUri = URI.createURI(uri)
							includedUri = includedUri.resolve(resource.URI)
							if(uniqueImportURIs.add(includedUri)) {
								collectImportUris(resource.getResourceSet().getResource(includedUri, true), uniqueImportURIs)
Re: How to import implicitly the namespace from importURI [message #1807149 is a reply to message #1807083] Thu, 23 May 2019 17:37 Go to previous message
Christian Dietrich is currently offline Christian DietrichFriend
i dont understand your question
what import uri scoping does:
- it filters all resources rejecting these that are not imported from global scope
- => the global scope is still all resource in the resourceset in standalone mode and all inside the project in eclipse
- the name part i did not understand. you may have a look what normal importscope does with aliasedeobjectdescriptions
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/xtext/
Twitter : @chrdietrich
Previous Topic:Separate java application that parses a file
Next Topic:Can Xtext be used to create general-purpose programming languages?
Current Time: Wed Feb 26 17:24:22 GMT 2020
Powered by FUDForum. Page generated in 0.08157 seconds
