Home » Modeling » EMF » how to load EFeatureMapEntry of the referred ecore using XMI Resource load(EMF FeatureMapEntry load )
how to load EFeatureMapEntry of the referred ecore using XMI Resource load [message #1806924] Fri, 17 May 2019 17:00 Go to next message
Harikarthik PC is currently offline Harikarthik PCFriend
I have a ecore(A.ecore) generated based on xsd. The generated ecore contains mixed attributes.
I need to use the above ecore(A) as a part of sirius based another ecore(B.ecore).
I used load resource option in EMF, to load the resource(A.ecore) in B.
B.ecore :
--> Class BClass
---->mixedB : EFeatureMapEntry [ with Extended metaData and wildcard entry set]
---->init : InitType [EReference with Containment true ]
A.ecore :
--> InitType
---->anotherClassObj : AnotherClass [EReference with containment true]
----> Class AnotherClass
-------->mixedA : EFeatureMapEntry [ with Extended metaData and wildcard entry set]
Problem 1 : when I try to load B.ecore as XMIResource, the mixed though it gets persisted, while loading the mixed text is not getting resolved
Problem 2 : I loaded the B.ecore as XMLResource, the mixedB is getting resolved, but,
though I am able to persist InitType and mixed data under B using ecore sample editor, it is unable resolve anotherClassObj of A while loading.It says feature not found exception
<BClass>
<init>
<anotherClassObj>5</anotherClassObj>
</init>
</BClass>
I need to persist and load like the above xml .
What is the best approach to solve this using EMF.
Thank you.
Re: how to load EFeatureMapEntry of the referred ecore using XMI Resource load [message #1806926 is a reply to message #1806924] Fri, 17 May 2019 21:07 Go to previous messageGo to next message
When your model is based on a *.xsd, an XyzResourceFactoryImpl is generated (with the necessary options for processing the extended metadata options on your *.ecore model) so you should ensure that this factor is used to create the resources used to load and save your model instances; generally there will be a registration in the plugin.xml to use that factory, so you should ensure your file extension is unique so that your registered factory is used. Do not use some arbitrary XMIResourceImpl that's created by some other resource factory.
Re: how to load EFeatureMapEntry of the referred ecore using XMI Resource load [message #1807101 is a reply to message #1806926] Wed, 22 May 2019 15:39 Go to previous messageGo to next message
Thanks for your reply Ed.
"should ensure that this factor is used to create the resources used to load and save your model instances; generally there will be a registration in the plugin.xml to use that factory, so you should ensure your file extension is unique so that your registered factory is used"
-- Could you please share a link or snippet, how to do this?
Re: how to load EFeatureMapEntry of the referred ecore using XMI Resource load [message #1807102 is a reply to message #1807101] Wed, 22 May 2019 15:52 Go to previous message
Everything you need is normally generated. What's in your plugin.xml right now?
Previous Topic:How can I add an ECore Modeling Project into my CDO Repository
Next Topic:Error "An Exception occurred while dispatching debug events" while executing acceleo Trans
Current Time: Mon Sep 16 13:03:16 GMT 2019
Powered by FUDForum. Page generated in 0.01809 seconds
