installing on Win10 with Java version 8 but installer could not find java [message #1806918] |
Fri, 17 May 2019 14:58 |
Jorge Valles Messages: 1 Registered: May 2019 |
I am trying to install the Eclipse 2019-03, before that I installed Java runtime environment 1.8.0_211. So when clicking on the eclipse installation file "eclipse-inst-win64.exe" it open a web page indicating "The java verion needed to run Eclipse installer couldn't be found on your system. You need the following version or a higher version Java 1.7.0 (64Bit)"
Just to confirm I had already installed the java, i go to the command prompt and typed "java -version" which confirmed I had already version 1.8.0.
So trying the eclipse installation only go to that webpage.
I am currently downloading the "jdk-12.0.1_windows-x64_bin.exe" hoping that will solve the issue.
Update:
JDK-12.0.1 .... also did not solved the issue. However, downloading the "eclipse-inst-win64.exe" again but from the webpage when trying to run the original one, it actually worked.
[Updated on: Fri, 17 May 2019 19:18] Report message to a moderator
FUDForum. Page generated in 3.10637 seconds
