Re: Eclipse/papyrus crash [message #1806922 is a reply to message #1806917] |
Fri, 17 May 2019 15:53 |
Camille Letavernier Messages: 952 Registered: February 2011 |
Hi Stephen,
Unfortunately, Papyrus isn't well tested on Linux. Especially, depending on the version of Eclipse, either GTK2 or GTK3 may provide higher stability. I believe SWT dropped GTK2 support recently (Around Eclipse 2018/12), so there's not much you can do - you're stuck with GTK3 now
I believe this kind of error is related to SVG Rendering in Papyrus (Most likely to happen when lots of SVGs are involved, and the Activity Diagram uses SVGs for each non-rectangle node, including Decision Node). I'm not sure who's responsible for this kind of error (Is it a bug in SWT/GTK? Is it something that Papyrus/GMF/Batik SVG Renderer is doing wrong?), or how to investigate this
Camille
Camille Letavernier
Re: Eclipse/papyrus crash [message #1806969 is a reply to message #1806922] |
Mon, 20 May 2019 11:11 |
well, while more people in the Papyurs development team use Windows, I'm a Linux user and regularly test current Papyrus versions. Concerning this error, it's apparently related to the use of SVG images. I've reported Bug 544501 - so far without resolution. I also tried to set the SWT_CAIRO environment variable, but this did not change the problem.
Best
Ansgar
Re: Eclipse/papyrus crash [message #1807037 is a reply to message #1807031] |
Tue, 21 May 2019 14:56 |
I can reproduce the problem, as soon as an SVG shape is shown in the diagram. A not very nice workaround is to disable SVG shapes via the following "style" setting: you loose graphical information, but avoid a crash.
svgFile : "none"
Re: Eclipse/papyrus crash [message #1807978 is a reply to message #1807203] |
Thu, 13 June 2019 14:58 |
Hi Steve,
I'm happy that the problem is apparently no longer reproducible with milestone 3 of 2019-06, though there is no specific patch for the bug i.e. is likely solved as a side-effect of another bug. Can you please test by downloading a developer release?
Concerning 535214, I don't think the two are related - but I left the reference for the moment.
Ansgar
FUDForum. Page generated in 0.03944 seconds
